FTP Support on ACE Module
Hi All,
Can any one tell me if the FTP Active and Passive loadbalancing on the ACE Module ?? Is there any cisco document on this or the examples to configure it?
thanks in advance.
2 Accepted Solutions
If you want to enable both Active & Passive FTP then use the following config
serverfarm host FTPSERVERS
probe FTP-Probe
rserver FTP-Real1
inservice
rserver FTP-Real2
inservice
class-map match-all FTP-CLASS
match virtual-address 10.10.10.1 tcp eq ftp
class-map match-all FTP-PASV-CLASS
match virtual-address 10.10.10.1 tcp eq any
policy-map type loadbalance first-match ftp-policy
class class-default
serverfarm FTPSERVERS
policy-map multi-match FTP
class FTP-CLASS
loadbalance vip inservice
loadbalance policy ftp-policy
loadbalance vip icmp-reply active
inspect ftp
class FTP-PASV-CLASS
nat dynamic 100 vlan 10
service-policy input FTP
interface vlan 10
ip address 10.10.10.100 255.255.255.0
nat-pool 100 10.10.10.1 10.10.10.1 netmask 255.255.255.255
no shutdown
For passive FTP the changes are to ensure that data channel is also natted.
Syed Iftekhar Ahmed
I am afraid there is no such link.
Just read how passive ftp works and translate it to ACE config.
Syed Iftekhar Ahmed
14 Replies 14
Here is a sample config
probe FTP-Probe
rserver FTP-Real1
inservice
rserver FTP-Real2
inservice
class class-default
class FTP-CLASS
inspect ftp
Syed Iftekhar Ahmed
Hello Iftekhar,
Thanks for the update,
I know that I should use ftp inspect to prepare data connections, but I have not found any mentions is this supporting both types of ftp.
Can you plz though a light on this where to look for active and passive? Any cisco document for the same to have detailed explanation??
probe FTP-Probe
rserver FTP-Real1
inservice
rserver FTP-Real2
inservice
class class-default
class FTP-CLASS
inspect ftp
interface vlan 10
no shutdown
Syed Iftekhar Ahmed
Hello Syed,
Thanks for the clear explanation of this.This is what i was looking for
Just wondering frm where did you got this info as i serached the whole cisco site but did nt got this information there?
I apriciate if you could share the link.
Syed Iftekhar Ahmed
Hi Syed,
Thanks a ton for the answer.
Hi Syed,
There is: class-map match-all FTP-PASV-CLASS
Why there is any? In basic passive config there is like this:
Could act + pass be like this:
Thanks in advance.
Usman please read my following response for tftp loadbalancing and it will give you an idea what I meant in the FTP config.
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Data%20Center&topic=Application%20Networking&topicID=.ee7814f&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cc1d06f
Syed Iftekhar Ahmed
yes, can be eq ftp, however no need for the second part at all.
actually, there is no need to have separate config for active or passive. ACE can take care of the translation of embedded ip and can proxy the corresponding second channel well for both active and passive mode.
tested on ver A2(1.0)
So basically what you mean is that when you are matching on ftp (eq ftp), and you specify to inspect the ftp data-channel (inspect ftp) in your policy-map, it will support both active and passive initiated connections, without the need of the additional config that iftekhar has made?
We would get something like this and it supports both active and passive ftp?
probe FTP-Probe
rserver FTP-Real1
inservice
rserver FTP-Real2
inservice
class-map match-all FTP-ACT-PASV-CLASS
class class-default
class FTP-ACT-PASV-CLASS
inspect ftp
interface vlan 10
no shutdown
Thanks for the update.
acennami
What about FTP where the server is behind the loadbalancer and is NAT'd on the way out...
The config below works in 1.6, but in 2.0 train I get a message: Error: This class doesn't have tcp protocol and a specific port
Since upgrading I can't seem to create a L3 access list, and my inspect ftp statements appear to be broken on the outbound NATs. Inbound/VIPs are OK, because I created specific VIPs for FTP which accept the 'inspect ftp' command.
access-list src-nat-jedi1p-ftp line 230 extended deny ip host 10.162.74.161 10.1
22.0.0 255.255.0.0
class-map match-any SRC-NAT-jedi1p
2 match access-list src-nat-jedi1p
policy-map multi-match NAT-Policy
class SRC-NAT-jedi1p
nat dynamic 34 vlan 310
inspect ftp --> this command is rejected and I cannot create an ACL with layer 3 properties/permissions.
In new code you cannot use "inspect ftp" under non-ftp VIP.
************** doesnt work ***************************
class-map match-any non-ftp-VIP
2 match virtual-address 1.1.1.1 any
policy-map multi-match xyz
class non-ftp-VIP
inspect ftp
***********Works*************************************
class-map match-any VIP-FTP
2 match virtual-address 1.1.1.1 tcp eq ftp
class non-ftp-VIP
inspect ftp
<--- No complains....
Syed Iftekhar Ahmed
That much I understand, but I am trying to apply this on an outbound NAT policy, not a virtual-server VIP policy.
I've been able to fix the FTP inspection on the VIPs in the manner described, but this does not help me for the outbound NAT connections which pass through the "NAT-Policy"
Hi all,
with versio 2.1.0 may you know uf there's some FTP bug?
i'll explain....sometimes (3 of 10 times) ftp from windows client (filezilla and WinScp) does not work :(.
topology is: msfc-->ace-->fwsm1+fwsm2-->ace--real
i've got mac-sticky enable and fw load balancing configure well (Cisco guideline) when i see ftp not working i noticed this stuff:
ACE# show conn address netmask 255.255.255.255
conn-id np dir proto vlan source destination state
93675 1 in TCP 5 :1082 :21 ESTAB
8493 1 out TCP 3 :21 :1082 ESTAB
23308 1 in TCP 5 :0 :34157 SYNACK
44250 2 in TCP 5 :0 :34157 SYNACK
how can i see mac-sticky feature in some show command and above all why i can see port0 (reserved) used and as second conn '--'?
thk
Das
