IP SLA with ICMP and TTL
Sep 10th, 2008
I would like to configure a "ip sla" based on ICMP but with a specific TTL. Is this possible?
(Based on IP (not MPLS))
Ian Wilson Thu, 09/25/2008 - 11:56
The following example configures an IP SLA instance to send an ICMP Echo (ping) packet every 3 seconds.
Timeout is set to 1 second, and threshold is set to 2 milliseconds.
If the ICMP reply is received within 1 second (timeout value) then the IP SLA 'operation return code' is 'OK'.
If the reply is received between 2 millisecs and 1 second then OverThreshold is set.
ip sla 1
type echo protocol ipIcmpEcho 10.51.12.4 <<< Ping operation
timeout 1000 <<< Timeout in 1 sec
frequency 3 <<< Ping every 3 secs
threshold 2 <<< 2 mS threshold
request-data-size 1400
ip sla sched 1 start-time now life forever <<< Shedule operation to start now and run forever
Ian
2044418Puts Sat, 09/27/2008 - 02:38
Thanks for your reply, but I would like to verify reachability with a specific TTL (hop count). For example:
The tracker should return OK only if the host to ping is only 2 hops away, but not if it is 3 hops away. For example due to a change in one of the intermediate router's routing table.
Please let me know if this is possible. Thanks
akharmanbiz Sun, 09/28/2008 - 10:15
I think no solution for ttl in ip sla monitor or if exist you must upgarde your IOS image.
Florin Barhala Mon, 10/29/2012 - 09:54
Any new idea regarding this request? I need to monitor a connection but I have to be sure the reply comes from ONE hop distance.
I require this because the ping_server_for_ISP1  I use is reachable using both ISP and I cannot know when ISP 1 is down (I originate icmp packets from ISP1_connected_interface). Here is the config if helps anyway:
ip sla monitor 10
type echo protocol ipIcmpEcho 193.aa.bb.201 source-ipaddr 89.xx.yy.18
timeout 1000
frequency 4
ip sla monitor schedule 10 life forever start-time now
track 10 rtr 10 reachability
delay down 10 up 30
ip route 0.0.0.0 0.0.0.0 89.238.226.17 track 10
cadet alain Mon, 10/29/2012 - 10:44
if you want to get sure the IP SLA probe is sent to first ISP then either use:
- source-interface in your IP SLA config
- configure a static host route for the destination you are probing
- configure a local PBR policy to always send the SLA probes out the interface to first ISP
I've never heard about an option for setting  TTL of ICMP echo-request for IP SLA.
Regards.
Alain
Florin Barhala Mon, 10/29/2012 - 11:05
Hi Alain,
I configured IP SLA using "source-interface in your IP SLA config"; but here it is:
- ISP1_ping_server goes down and primary default route is removed from routing table
- then ISP2_default route comes in place and then ISP1_ping_server is reachable using ISP2 connection. This triggers
primary default route to get up and so on...
Any ideas?
I use IOS Version 12.4(25b).
cadet alain Mon, 10/29/2012 - 11:26
Try of of the other 2 workarounds I proposed and tell me.
Regards.
Alain
Florin Barhala Mon, 10/29/2012 - 11:56
Hi Alain,
2nd path sends me to the same result, as the static route uses 1st ISP; but when it fails the ISP1_ping_server will be reached using the DEFAULT route from the 2nd ISP.
I believe it shouldn't behave this way as long as I use the source_interface option in the ip sla configuration, nevertheless I will dig more on this issue.
cadet alain Mon, 10/29/2012 - 12:56
no it shouldn't behave this way but having the full config could maybe help us to troubleshoot this.
Regards.
Alain
