booting problem in l3 catalyst 4006 switch
Sep 10th, 2008
I m facing problem in booting the catalyst 4006 switch
1) it has supervisor III engine.
the symptoms are- it is showing blinking red on Status LED
2) It is not giving any output when i m connecting it by console.
glen.grant Wed, 09/10/2008 - 03:22
  • Purple, 4500 points or more
Not much to go on , if you are getting no output from the console and you are sure your emulator settings and cable are correct then its time to get the supervisor replaced.
