Reg:1720 router acl
dhanikonda
Dear sir,
A web server is hosted on 202.71.156.61. After we have
applied the access list as per your mail, site on port
81 is not getting accessed from outside.
Acl on router isaccess-list 101 permit ip 202.63.113.32 0.0.0.15 host 202.71.156.61
access-list 101 permit ip host 121.246.166.101 host 202.71.156.61
access-list 101 permit ip host 209.204.131.3 host 202.71.156.61
access-list 101 deny ip any host 202.71.156.61
access-list 101 permit ip any any
int S0/0
ip access-group 101 in
plz tell me how can i access my web server
BUT i am unable to access this server from outside
any tips for this
srini
satish_zanjurne
Level 4
Level 4
1.If you want to make this server accessible from outside , and from any host , then above access list denies that , you need to remove it & keep the server open !!!
2.It allows access from 202.63.113.32-46
IT allows access from 121.246.166.101
IT allows access from 209.204.131.3
So if you are accessing 202.71.156.61 from any of above IP address , you should be able to access it.
If , you want to access it from some other host, then add that IP address in permit list.
HTH..rate if helpful..
satish_zanjurne
Level 4
Level 4
