The difference b/w 2 SKUs
Answered Question
Sep 10th, 2008
Want to understand the difference b/w to GPL SKUs:
Part Number: MCS-7816-I3-IPC1
Description: HW Only MCS-7816-I3 with 2GB RAM and One 160GB SATA HD
and
Part Number: MCS7816I3-K9-CMB2
Description: Unified CM 6.1 7816-I3 Appliance, 0 Seats
The price is the same for both entries. The hardware, I think, is also
similar. I suppose the first one (MCS-7816-I3-IPC1) does not contain any
CD/DVD software package. Whereas the second one (MCS7816I3-K9-CMB2) does.
Am I right ?
Are there any other differences ?
Correct Answer by Rob Huffman about 8 years 10 months ago
Hey Tobivan,
Life is great here! Hopefully for you as well :)
The "CMA/CMB" designation on the Part# does indicate a "pre-loaded" appliance. So yes, this server would be shipped with the Linux OS and Communications Manager 6.1 pre-loaded. The "IPC1" Version will not ship with any CCM discs and they will need to be ordered seperately :)
Here are some examples;
The server appliance is preinstalled with an operating system and the Cisco Unified Communications Manager application. Cisco Unified Communications Manager is fully operational upon startup, requiring entry of just a few configuration variables such as IP address and domain.
Product part number
MCS7816H3-K9-CMB2
Preload
Cisco Unified Communications Manager 6.1
OS
Included
CMB1 = Cisco Unified Communications Manager 6.0
CMB2 = Cisco Unified Communications Manager 6.1
CMA2 = Cisco Unified Communications Manager 5.1
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/ps7301/product_data_sheet0900aecd805efb99.html
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Rob Huffman Wed, 09/10/2008 - 05:00
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hey Tobivan,
Hope all is well my friend! Maybe after my mistakes from last week I should steer clear but....
The MCS7816I3-K9-CMB2 is actually a "pre-loaded" Appliance with CCM 6.1
MCS-7816-I3-IPC1
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/product_data_sheet0900aecd805e6fc2.html
MCS7816I3-K9-CMB2 = Unified CM 6.1 7816-I3 Appliance, 0 Seats
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps556/ps7036/end_of_life_notice_c51-487656.html
Cisco Unified Communications Manager Server Support Matrix
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
Hope this helps!
Rob
Tobivan_Helden_2 Sun, 09/14/2008 - 22:59
Hey, Rob.
I hope you are fine.
When you saying 'the MCS7816I3-K9-CMB2 is a "pre-loaded" appliance with CUCM 6.1'
you mean that I got the server in the box that has already CUCM installed as Operating
System by vendor ? Or I got only server with DVD discs with CUCM software that I must install manually ?
Also does MCS-7816-I3-IPC1 contain any discs in the box ?
Thank you.
Correct Answer
Rob Huffman Mon, 09/15/2008 - 04:44
  • Hall of Fame,
    Founding Member
Hey Tobivan,
Product part number
MCS7816H3-K9-CMB2
Preload
OS
Included
Hope this helps!
Rob
Rob Huffman Tue, 09/16/2008 - 04:36
  • Hall of Fame,
    Founding Member
Hi Tobivan,
You are most welcome. It's always a pleasure my friend!
Cheers,
Rob
denny3333 Tue, 09/16/2008 - 23:57
MCS-7816-I3-IPC1 is a server ready for Call Manager 4.x which is Windows based.
MCS7816I3-K9-CMB2 is a server ready for Call Manager version 6.1 which is Linux based.
No CD/DVD is available with either models.
Hope this answers your queries.
Denny
