alalli Wed, 09/10/2008 - 04:19
Good Day,
For less than 100 users, you might be better off using an IOS based firewall.
arupbiet2006 Wed, 09/10/2008 - 04:23
thanks for your reply.kindly tell me the model no.should be cisco(less than 100 and also 100 user)
Marwan ALshawi Wed, 09/10/2008 - 04:33
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
u can use ASA or IOS firewall
both good
but there is a cisco routers seriese called ISR which is exacly all in one also in diffrent sizes this works for voice, security like IPS, firewall and much more cpabilities in one box
ISR 1800:
http://www.cisco.com/en/US/products/ps5853/index.html
ISR 2800:
http://www.cisco.com/en/US/products/ps5854/index.html
ASA:
http://www.cisco.com/en/US/prod/collateral/vpndevc/ps6032/ps6094/ps6120/prod_brochure0900aecd8048dba8.html
IOS:
http://www.cisco.com/en/US/products/sw/secursw/ps1018/index.html
good luck
if helpful Rate
satish_zanjurne Wed, 09/10/2008 - 04:40
  • Silver, 250 points or more
ASA/PIX will be good..
Except ASA 5505 , all other supports unlimited users in Base License in 8.0 software
PIX 515,525,535 all supports unlimited users in Restricted , Unrestricted , Failover, Active-Active failver licenses.. in 8.0 software
But in 7.0 it has limitations like
ASA 5510 32K concurrent connections
ASA 5520 130K -----"-------
ASA 5540 280K -----"-------
PIX 515 48K -----"-------
PIX 525 140K -----"-------
PIX 535 250K -----"-------
See below link for more information of licensing..
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/specs.html
http://www.cisco.com/en/US/docs/security/asa/asa70/configuration/guide/specs.html
HTH...rate if helpful..
