5.0.4a update to 5.0.4c fails with error
Sep 10th, 2008
ERROR: System info not updated by InstallWizard on new partition
I have done a google and am unable to find anything remotely helpful on this.
The customer is running 5.0.4.2000-2 and on the rare occasion can than allow downtime we wanted to update to 5.0.4.4000-2.
The file was copied to the server all ok, it was check summed all ok at all steps.
it started the process fine, except at it the displayed the message:
I attach the full log it generates for perusal.
Any thoughts are appreciated, and an answer even more.
NeilW
ebreniz Tue, 09/16/2008 - 16:29
  • Silver, 250 points or more
I suspect you are hitting CSCsh40122. I think you have to restart the cluster. And also see ValidateNetworking.sh runs
neil.woolloff Mon, 09/22/2008 - 02:03
Thanks ebreniz, and apologise for any delay in responding.
Had to restart the Pub due to CiscoTSP issues, but then headed of on holiday :)
Will have a look through the Bug ID and see if it helps.
Do you think the Sub would also need a reboot?
[edit]
CSCsh40122 - appears to be only viewable by cisco employess. Is it poosible to see nay further info??
[/edit]
