Why can't our ISP see our network advertised via bgp
Sep 10th, 2008
We are implimenting a new subnet
172.20.255.8/255.255.255.248
172.20.255.9 HSRP VIP gw
172.20.255.10 router A
172.20.255.11 router b
172.20.255.12
172.20.255.13
172.20.255.14
172.20.255.15
I have configured the .10 address as a secondary IP address on one of the ethernet interfaces. But our ISP is saying they do not see us sending the route, but I believe we have it configured correctly
router ospf 711
log-adjacency-changes
redistribute connected subnets
redistribute bgp 65002 subnets
network 192.168.2.0 0.0.0.255 area 1
network 192.168.100.0 0.0.0.255 area 1
network 192.168.118.0 0.0.0.255 area 1
network 192.168.255.0 0.0.0.255 area 1
router bgp 65vv2
no synchronization
bgp log-neighbor-changes
network 192.168.255.128 mask 255.255.255.248
redistribute ospf 711 match internal external 1 external 2 route-map none-from-
bgp
neighbor 192.168.255.10 remote-as 3561
neighbor 192.168.255.10 prefix-list fr-3561 in
neighbor 192.168.255.10 prefix-list to-3561 out
no auto-summary
ip prefix-list fr-3561 seq 5 deny 192.168.1.0/24
ip prefix-list fr-3561 seq 6 deny 192.168.21.0/24
ip prefix-list fr-3561 seq 10 permit 192.168.0.0/16 le 32
ip prefix-list fr-3561 seq 15 permit x2.1x.37.xxx/26 le 32
ip prefix-list fr-3561 seq 20 permit 2x.xx.135.xxx/26 le 32
ip prefix-list fr-3561 seq 25 permit 6x.14.xx.xxx/28 le 32
ip prefix-list fr-3561 seq 30 permit 172.30.0.0/16 le 32
ip prefix-list fr-3561 seq 35 permit 172.20.0.0/16 le 32
ip prefix-list to-3561 seq 5 deny 192.168.1.0/24
ip prefix-list to-3561 seq 10 permit 192.168.0.0/16 le 32
access-list 2 permit 192.168.1.0 0.0.0.255
access-list 150 deny ip host 192.168.2.15 any
access-list 150 permit ip any any
route-map none-from-bgp deny 10
match tag 3561
route-map none-from-bgp permit 20
This is what our ISP has in their router
access-list 45 permit 172.20.0.0 0.0.255.255
ISProuter#show ip bgp neighbors 192.168.255.9 received-routes BGP table version is 81678, local router ID is 192.168.255.10 Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
*> 192.168.2.0 192.168.255.9 0 0 65002 ?
* 192.168.255.8/30 192.168.255.9 0 0 65002 ?
*> 192.168.255.44/30
192.168.255.9 2 0 65002 ?
*> 192.168.255.128/29
192.168.255.9 0 0 65002 i
Total number of prefixes 4
Overall Rating: 5 (2 ratings)
satish_zanjurne Wed, 09/10/2008 - 07:06
  • Silver, 250 points or more
hi
can you see the secondary address in your routing table ??
can you paste the output of your routing table ??
nygenxny123 Wed, 09/10/2008 - 07:29
currently i only have the .9-.11 configured on the routers..but im not sure they would be able to if they arent seeing the network
nygenxny123 Wed, 09/10/2008 - 07:38
sure
myrouter#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level
ia - IS-IS inter area, * - candidate default, U - per-user static r
o - ODR, P - periodic downloaded static route
Gateway of last resort is 192.168.2.246 to network 0.0.0.0
B 192.168.166.0/24 [20/5003] via 192.168.255.10, 4d11h
B 192.168.88.0/24 [20/5003] via 192.168.255.10, 4d11h
B 192.168.13.0/24 [20/4] via 192.168.255.10, 3w4d
B 192.168.167.0/24 [20/5003] via 192.168.255.10, 5d13h
B 192.168.133.0/24 [20/5003] via 192.168.255.10, 4d11h
B 192.168.14.0/24 [20/5] via 192.168.255.10, 3w4d
B 192.168.151.0/24 [20/5003] via 192.168.255.10, 01:44:52
B 192.168.164.0/24 [20/5003] via 192.168.255.10, 1d05h
192.168.120.0/24 is variably subnetted, 2 subnets, 2 masks
B 192.168.120.0/24 [20/5003] via 192.168.255.10, 4d11h
B 192.168.120.248/29 [20/4] via 192.168.255.10, 3w4d
B 192.168.15.0/24 [20/4] via 192.168.255.10, 3w4d
B 192.168.150.0/24 [20/5003] via 192.168.255.10, 3d22h
B 192.168.165.0/24 [20/5003] via 192.168.255.10, 4d11h
B 192.168.93.0/24 [20/5003] via 192.168.255.10, 4d11h
B 192.168.162.0/24 [20/5003] via 192.168.255.10, 4d11h
B 192.168.9.0/24 [20/4] via 192.168.255.10, 1w4d
B 192.168.92.0/24 [20/4] via 192.168.255.10, 3w4d
B 192.168.163.0/24 [20/5003] via 192.168.255.10, 1w0d
B 192.168.10.0/24 [20/4] via 192.168.255.10, 1w4d
B 192.168.160.0/24 [20/5003] via 192.168.255.10, 07:25:41
172.20.0.0/16 is variably subnetted, 4 subnets, 2 masks--------
B 172.20.255.0/29 [20/5003] via 192.168.255.10, 1w4d----------
C 172.20.255.8/29 is directly connected, GigabitEthernet0/1-----------------
B 172.20.255.32/29 [20/4] via 192.168.255.10, 4d06h--------
B 172.20.0.0/16 [20/4] via 192.168.255.10, 1w4d------
B 172.30.0.0/16 [20/4] via 192.168.255.10, 1w4d--------
192.168.124.0/32 is subnetted, 6 subnets
B 192.168.124.100 [20/5003] via 192.168.255.10, 03:55:58
B 192.168.124.101 [20/5003] via 192.168.255.10, 02:33:24
B 192.168.124.102 [20/5003] via 192.168.255.10, 02:42:37
B 192.168.124.103 [20/5003] via 192.168.255.10, 02:21:43
B 192.168.124.96 [20/5003] via 192.168.255.10, 01:37:48
B 192.168.124.97 [20/5003] via 192.168.255.10, 01:34:13
B 192.168.161.0/24 [20/5003] via 192.168.255.10, 4d11h
B 192.168.251.0/24 [20/4] via 192.168.255.10, 1w4d
192.168.157.0/29 is subnetted, 2 subnets
rsgamage1 Wed, 09/10/2008 - 09:24
  • Bronze, 100 points or more
What does your show ip bgp neighbor [isp-bgp peer IP] advertised-routes say ?
nygenxny123 Wed, 09/10/2008 - 10:08
myrouter#sh ip bgp neighbors 192.168.255.10 advertised-routes
BGP table version is 48381, local router ID is 192.168.255.130
*> 192.168.2.0 0.0.0.0 0 32768 ?
*> 192.168.255.8/30 0.0.0.0 0 32768 ?
192.168.2.247 2 32768 ?
0.0.0.0 0 32768 i
cfolkerts Wed, 09/10/2008 - 08:11
You can't redistribute into one routing protocol then redistribute again into another routing protocol. You have a few options.
router ospf 711
network 172.20.255.8 0.0.0.7 area 1
or
router bgp 65xxx
network 172.20.255.8 mask 255.255.255.248
or
router bgp 65xxx
nygenxny123 Wed, 09/10/2008 - 10:25
cfolkerts
Is it that im not advertising at all or am redistributing twice?
cfolkerts Wed, 09/10/2008 - 10:29
You are not advertising it at all. You can verify this by issuing the command "show ip bgp neigh x.x.x.x advertised-routes" which appears that you have done already. Just add the network command to BGP and all will be OK.
router bgp 65xxx
nygenxny123 Wed, 09/10/2008 - 11:43
thx..will do
I went into another sites router..basically the same config..and looked it over..we are also adding a different subnet..but i dont see where it is advertised
Yet..BGP is advertising it from the sh ip
bgp nei........advertised routes
router ospf 711
router-id 192.168.92.251
redistribute static subnets
redistribute bgp 65007 subnets
network 192.168.92.0 0.0.0.255 area 1
router bgp 65007
no synchronization
bgp
neighbor 192.168.255.30 remote-as 3561
neighbor 192.168.255.30 prefix-list fr-3561 in
neighbor 192.168.255.30 prefix-list to-3561 out
no auto-summary
ip prefix-list fr-3561 seq 15 permit 64.14.47.xx/26 le 32
ip prefix-list fr-3561 seq 20 permit 216.74.135.xxxx/26 le 32
ip prefix-list fr-3561 seq 25 permit 64.14.46.xxx/28 le 32
ip prefix-list fr-3561 seq 30 permit 172.20.0.0/16 le 32
ip prefix-list to-3561 seq 15 permit 172.20.255.32/29 le 32
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 25 permit 192.168.0.0 0.0.255.255
myrouter#sh ip bgp neighbors 192.168.255.30 advertised-routes
BGP table version is 66093, local router ID is 192.168.255.29
*> 172.20.255.32/29 0.0.0.0 0 32768 ?
*> 192.168.92.0 0.0.0.0 0 32768 ?
*> 192.168.255.28/30
0.0.0.0 0 32768 ?
*> 192.168.255.32/30
192.168.92.252 20 32768 ?
rsgamage1 Wed, 09/10/2008 - 12:06
172.20.255.32/29 is redistributed into BGP. ? sign indicates as incomplete meaning that it's being redistributed. Check directly connected networks. You should see this network in your routing table as directly connected.
nygenxny123 Wed, 09/10/2008 - 12:28
hi rsmage1, i checked the second site and this is what i have for that network
172.20.0.0/16 is variably subnetted, 3 subnets, 2 masks
B 172.20.255.0/29 [20/5004] via 192.168.255.30, 4d10h
C 172.20.255.32/29 is directly connected, GigabitEthernet0/1
B 172.20.0.0/16 [20/4] via 192.168.255.30, 4d10h
but in the first site example i also show that network as connected..wouldnt it also be advertised?
B 192.168.160.0/24 [20/5003] via 192.168.255.10, 12:16:50
B 172.20.255.32/29 [20/4] via 192.168.255.10, 4d10h
router ospf 711
redistribute bgp 6x02 subnets
cfolkerts Wed, 09/10/2008 - 12:34
Check the difference between the bgp configuration between your first and second sites.
rsgamage1 Wed, 09/10/2008 - 12:35
So you are redistributing 172.20.255.8/29 connected network into BGP with,
router bgp 65007
redistribute connected.
I suppose you could do the same thing on your first router such that it will advertise your /29 network to ISP via BGP.
cfolkerts Wed, 09/10/2008 - 12:24
Under the router bgp 65007, the command "redistribute connected" is implemented. This will advertise the network 172.20.255.32/29 since it is connected.
nygenxny123 Thu, 09/11/2008 - 06:08
ok i updated the bgp config and still no go.hmm
router bgp 65002
no synchronization
bgp
no auto-summary
ip route 6c.14.cc.ccc 255.255.255.255 192.168.100.253
ip route 6c.14.47.ccc 255.255.255.255 192.168.100.249
ip route 192.168.1.0 255.255.255.0 192.168.100.249
ip route 192.168.1.0 255.255.255.0 192.168.100.253
BGP table version is 48498, local router ID is 192.168.255.130
0.0.0.0 0 32768 i
interface GigabitEthernet0/1
description ToLocal LAN
ip address 192.168.2.236 255.255.255.0 secondary
ip address 172.20.255.10 255.255.255.248 secondary
ip address 192.168.2.245 255.255.255.0
rsgamage1 Thu, 09/11/2008 - 06:27
On your second site you have a prefix-list applied for 172.20.255.32/29
So you have to apply the corresponding prefix-list for outbound BGP traffic.
ip prefix-list to-3561 seq 15 permit 172.20.255.8/29 le 32
rsgamage1 Thu, 09/11/2008 - 06:51
With this change it should be working normally.
nygenxny123 Thu, 09/11/2008 - 06:54
so i have to apply a prefix list to my first site
ip prefix-list to-3561 seq 40 permit 172.20.255.8/29 le 32
I would have thought these prefix list would have already allowed it
rsgamage1 Thu, 09/11/2008 - 06:57
I would have thought these prefix list would have already allowed it ...
Well, if you check your BGP configuration you can see they are applied on inbound updates. I've also misread it initially.
rsgamage1 Thu, 09/11/2008 - 07:17
Yes,
ip prefix-list to-3561 seq 40 permit 172.20.255.8/29 le 32 should do the needful.
nygenxny123 Thu, 09/11/2008 - 07:26
thxx!
*> 172.20.255.8/29 0.0.0.0 0 32768 ?
0.0.0.0 0 32768 i
Total number of prefixes 5
now i just have to figure out why
didnt allow it initially...i dont see where
this was limited to inbound
rsgamage1 Thu, 09/11/2008 - 07:36
i dont see where this was limited to inbound..
router bgp 65vv2
does it.
rsgamage1 Thu, 09/11/2008 - 08:14
Have a look at,
neighbor {neighbor IP} prefix-list {Name} {in | out}
Here,
in filters "incoming" updates whereas
out filters "outgoing" updates.
Hope this will clarify your doubts.
nygenxny123 Thu, 09/11/2008 - 10:41
but isnt the out
and
the statement
would have allowed it to go out
allowing
rsgamage1 Thu, 09/11/2008 - 11:18
But these are two different prefix-lists
to-3561 and fr-3561
So if you want to match with outbound updates then it should be as follows;
ip prefix-list to-3561 seq 35 permit 172.20.0.0/16 le 32
