OSPF routing issue.
Sep 10th, 2008
Ok so here goes... I have a network (10.20.x.x) that is coming in over IPSEC-L2L then has to make it's way through our network (3hops) to some of it's destinations ... I can see the route advertised through Ospf on the core and on the router after the core facing next hope. On that router however I've had to put a static router because ospf doesn't seem to be advertising the routes for that network. Any trouble shooting hints would help
akbindal Wed, 09/10/2008 - 07:25
Do u have a network diagram to explain the topology on how the routers are connected and whether they are in same area..
Also try using sh ip ospf database command to check whether the route is actually injected in the ospf database at each hop to the destination end router where we want this network to be seen..
Akhil
Brent Rockburn Thu, 09/11/2008 - 05:57
Ok so after doing some investigation I've found that OSPF is actually broadcasting the route I want .. actually OSPF is doing exactly what it should do .. which is exactly what I don't want it to do .. so I need to know how to choose the path for OSPF.
Any ideas?
akbindal Sun, 09/14/2008 - 17:41
If u want a route to be stopped injecting in OSPF and advertised..u can filter the route using Filter commands..please let me know the exact scenario to apply correct route filtering..
Akhil
