Choosing a firewall
Sep 10th, 2008
I work for a video conferencing company and we are looking to get a new firewall as our current Adtran firewall has some issues with a certain codec.
We are a small company that is trying to keep it cheap but I also don't want to waste time on something that won't work for us. I've kind of narrowed it down to
ASA5505-UL-BUN-K9
and
ASA5505-SEC-BUN-K9.
The only difference I can seem to find is that the ASA5505-SEC-BUN-K9 offers 15 less IPSec VPN Peers. The price difference is $350 though and I can't wrap my head around 15 IPSec peers being worth $350. Is there something else obvious I'm missing? We won't have a need for those extra peers so should I just grab the ASA5505-UL-BUN-K9?
Thanks.
Overall Rating: 4 (1 ratings)
suschoud Wed, 09/10/2008 - 09:58
  • Gold, 750 points or more
I would recommend to look at long term consequences rather then existing ones.You never know when your setup could need more ipsec peers ( which would essentially result in migration to another device again )....
What you are missing by paying 350$ less ( other then ipsec peers.... :)
DMZ support, Stateless Active/Standby high availability, Dual ISP support.
So,you can have a dmz with this license,you can add one more asa for high availability and you can have 2 isp's terminating on asa so thatr if one fails,other one takes over automatically.
Please rate if helpful/
HTH,
Sushil
Sushil
