Call Forward to voicemail (via CFNA)
Sep 10th, 2008
Scenario is this:
ip phone -CFNA-> ip phone -CFNA-> (QSIG/6608E1) to Mitel PBX -> to Octel Voicemail
ip phone will call voicemail correctly
ip phone when CFNA to another phone calls voicemail, but does go to the correct VM box (goes to open tree).
Any ideas.
Mark.
Overall Rating: 3 (1 ratings)
testeven Wed, 09/10/2008 - 07:59
Hi!
I'm not very familiar with the Octel VM system, but this issue happens on Unity too. The problem is as follows.
When a user calls VM directly it goes to his greeting as it's a VM user.
When a call arrives to the VM server from another DN that is not recognized as a VM user it will play by default the opening greeting. In Unity we usually configure a call routing rule, not sure if you can do that in Octel, but basically say configure it so when a call comes in with forwarding extension XXXX send it to user's VM X and that's it.
clotheyes Wed, 09/10/2008 - 08:08
The Octel has the option of an alias - tried that - no luck.
Mark.
