Joe Clarke Tue, 09/09/2008 - 22:16
On Windows, you can run pdshow from a DOS prompt. On Solaris, run /opt/CSCOpx/bin/pdshow.
alejandro.cano Wed, 09/10/2008 - 10:34
Process= WlseUHIC
State = Running normally
Pid = 4680
RC = 0
Signo = 0
Start = 8/18/2008 10:29:36 PM
Stop = Not applicable
Core = Not applicable
Info = Started.
Process= AdapterServer1
State = Administrator has shut down this server
Pid = 0
RC = 1
Signo = 0
Stop = 9/10/2008 12:34:34 AM
Info = Server started by admin request
State = Program started - No mgt msgs received
Pid = 3864
RC = 0
Signo = 0
E:\Documents and Settings\acano>
Joe Clarke Wed, 09/10/2008 - 11:57
Try starting UPMProcess manually using the command:
pdexec UPMProcess
alejandro.cano Wed, 09/10/2008 - 11:59
ERROR: cmd failed. Server reason: Application UPMprocess is not registered. All requests to operate on this application
will be ignored.
Joe Clarke Wed, 09/10/2008 - 12:03
The command is:
pdexec UPMProcess
Case is important. However, that may not bring HUM up. Instead, try restarting all of dmgtd:
net stop crmdmgtd
net start crmdmgtd
alejandro.cano Wed, 09/10/2008 - 12:05
C:\Documents and Settings\net-eng>net stop crmdmgtd
System error 1060 has occurred.
The specified service does not exist as an installed service.
alejandro.cano Wed, 09/10/2008 - 12:15
I amgetting the same error again
Cannot communicate with Poller Manager Service. Check whether the UPMProcess is down.
Joe Clarke Wed, 09/10/2008 - 13:44
Please post a list of your Windows services and their startup parameters.
Joe Clarke Wed, 09/10/2008 - 14:59
This is fine. Now, shutdown Daemon Manager, and post the output of netstat -a -n -o -b.
Joe Clarke Wed, 09/10/2008 - 16:36
Some of the LMS processes are not stopping properly. I suspect this is due to CSCsm04957. You need to upgrade to DFM 3.0.3. In the meantime, if you reboot this server, you should get HUM to work again, but the problem will most likely return until you upgrade DFM.
alejandro.cano Thu, 09/11/2008 - 05:50
Awesome, the reboot fix it, I try looking for the DFM upgrade but no luck, I only see DFM 2.X upgrade. Any ideas?
Joe Clarke Thu, 09/11/2008 - 07:50
You can find DFM 3.0.3 from Common Services > Software Center > Software Update.
