How to handle"MSS exceeded" error message
Sep 10th, 2008
The ASA firewall's syslog messg indicates that the Public IP of the email server xx.xx.xx.ww/443 dropped TCP packets to the ASA public IP xx.xx.xx.yy/34018 due to MSS exceeded.
Is there a security or performance issue to allow all packets that exceed the MSS?
09-09-2008 09:34:37 Local4.Warning 192.168.xx.xx Sep 09 2008 09:43:12: %ASA-4-419001: Dropping TCP packet from outside:xx.xx.xx.ww/443 to Inside:xx.xx.xx.yy/34018, reason: MSS exceeded, MSS 1260, data 1460
Thanks.
Overall Rating: 4 (3 ratings)
suschoud Wed, 09/10/2008 - 08:38
Here are the commands :
ASA-5510-8x(config)# access-list http-list2 permit ip any any
ASA-5510-8x(config)# class-map http-map1
ASA-5510-8x(config-cmap)# match access-list http-list2
ASA-5510-8x(config-cmap)# exit
ASA-5510-8x(config)# tcp-map mss-map
ASA-5510-8x(config-tcp-map)# exceed-mss allow
ASA-5510-8x(config-tcp-map)# exit
ASA-5510-8x(config)# policy-map global_policy
ASA-5510-8x(config-pmap)# class http-map1
ASA-5510-8x(config-pmap-c)# set connection advanced-options mss-map
ASA-5510-8x(config-pmap-c)# exit
ASA-5510-8x(config-pmap)# exit
Do rate helpful posts.
Sushil
saidfrh Wed, 09/10/2008 - 08:52
Sushil,
In the 3-way TCP handshake, the length of the TCP packet is negotiated. When the packets are routed the length of the TCP packets exceed the negotiated length. Is the above normal?
Is there a security issue allowing all IP packets with differenet lengths to enter the firewall?
suschoud Wed, 09/10/2008 - 09:11
the default mss ( meximum segment size ) of 1380 is good enough for most of the ethernet networks.however,if a segment comes with a size of mode then 1380,firewall drops it.segments of size of more then 1380 is normal ,depending on what media is used for communication.Allowing such packets do not introduce any security risks....it's an add on security feature of asa which let you know that some packets are not following the default rfc standards.....i have never seen any issues when such packets are allowed through f/w ( believe me,in TAC,we see this every next day . :)
Please rate if helpful
Sushil
saidfrh Wed, 09/10/2008 - 10:03
Sushil,
This is a production firewall. Would copying and pasting your configuration effect the network?
suschoud Wed, 09/10/2008 - 10:44
Coulld you paste the show commands below :
sh run policy-map
sh run class-map
sh run service-policy
Accordingly,I would let you know.
Sushil
saidfrh Wed, 09/10/2008 - 11:34
policy-map type inspect dns migrated_dns_map_1
parameters
message-length maximum 1500
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect icmp error
class ips-class
ips inline fail-open
policy-map ips-pol
class ips-class
class-map ips-class
match access-list ips
class-map inspection_default
match default-inspection-traffic
service-policy global_policy global
suschoud Wed, 09/10/2008 - 11:36
Perfect,
Go ahead and add the commands with NO WORRIES.
Please rate if helpful. :)
Sushil
cnj_bucks Wed, 01/20/2010 - 07:25
We are having a similar issue.  We have an ASA5505 and on this network we have a scanner/copier that does scan to email.  We are noticing that when the copier/scanner attempts to contact an email server that resides on the other side of the tunnel, we are getting the 419001 error messages.
Will the code you posted work for this?  The destination port for this traffic is 25.
