adding print drivers to a remote CM
Sep 10th, 2008
We have had a large deployment of WAE 512's and need to configure them as print servers as well. Some of the printers we need to incorporate are "non standard" , such as Zerox, Lexmark, etc. However, we have the print drivers for those printers. The CM server is located in a remote site. Does anybody know if we could add the printer drivers to the CM's repository remotely?
thanks..
Zach Seils Wed, 09/10/2008 - 10:08
  • Cisco Employee,
Hi Greg,
Yes, you can add print drivers to the CM Print Repository remotely. It may take a bit longer since you are remote, but it still works the same.
Zach
