Another site to site VPN problem
Sep 10th, 2008
Hi, we are trying to do a site to site VPN from a Cisco 871 and a Cisco 2800 concentrator. The concentrator is running with the same config dozens of site to site VPN's. I think the problem is at the Cisco 871.
The Config in the 871:
Using 1652 out of 131072 bytes
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
enable password ********
no aaa new-model
dot11 syslog
ip cef
ip name-server 194.224.52.36
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
crypto isakmp key ****** address 213.192.208.***
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto map SDM_CMAP_1 6 ipsec-isakmp
description Numintel
set peer 213.192.208.242
set security-association lifetime seconds 86400
set transform-set ESP-3DES-SHA
match address 100
archive
log config
hidekeys
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
ip address 196.12.229.218 255.255.255.252
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface Vlan1
ip address 192.169.15.100 255.255.255.0
no ip redirects
no ip proxy-arp
ip nat inside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 196.12.229.217
no ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet4 overload
ip access-list extended Numintel
access-list 1 permit 192.169.15.0 0.0.0.255
access-list 100 permit ip 192.169.15.0 0.0.0.255 192.168.3.0 0.0.0.255
access-list 100 permit ip 192.169.15.0 0.0.0.255 192.168.4.0 0.0.0.255
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
password 2008
login
scheduler max-task-time 5000
end
crypto isakmp key ****** address 196.12.229.*****
crypto map SDM_CMAP_1 7 ipsec-isakmp
description ICOMP
set peer 196.12.229.***
match address 111
interface GigabitEthernet0/0
description VLAN COLLAB$ETH-LAN$
ip address 192.168.3.11 255.255.255.0
duplex auto
speed auto
access-list 111 permit ip 192.168.3.0 0.0.0.255 192.169.15.0 0.0.0.255
access-list 111 permit ip 192.168.4.0 0.0.0.255 192.169.15.0 0.0.0.255
The tunnel is up as the "sh krypto isakmp sa" command says at the 2800. But the 872 show no output when exececuting all the sh isakmp or ipsec commands. Is like it's dead.
Thank you very much, this one is driving me nuts.
Overall Rating: 2 (1 ratings)
Istvan_Rabai Wed, 09/10/2008 - 20:43
Hi Xavier,
I don't see isakmp policies configured on any of your routers.
Are they just cut from the text file or are they really missing from the configurations?
If they are missing, you should configure isakmp policies on both sides.
Please write if you need help in this.
Cheers:
Istvan
godzilla0 Thu, 09/11/2008 - 02:55
Thanks for answering, yes The policies are on both router, they are identical.
Marwan ALshawi Wed, 09/10/2008 - 21:29
u have nating enabled but u didnt configured nat exmption !!
u need to exclude the traffic going from lan to lan from the nating
on the first router
u need:
access-list 101 deny ip 192.169.15.0 0.0.0.255 192.168.3.0 0.0.0.255
access-list 101 deny ip 192.169.15.0 0.0.0.255 192.168.4.0 0.0.0.255
access-list 101 permit 192.169.15.0 0.0.0.255 any
then:
ip nat inside source list 101 interface FastEthernet4 overload
this is based on what is post
also u need to apply the same idea on the other router but using the following for nating:
access-list 110 deny ip 192.168.3.0 0.0.0.255 192.169.15.0 0.0.0.255
access-list 110 deny ip 192.168.4.0 0.0.0.255 192.169.15.0 0.0.0.255
access-list 110 permit ip 192.168.3.0 0.0.0.255 any
access-list 110 permit ip 192.168.4.0 0.0.0.255 any
check the crypto isakmp policy
the authentication shoud be pre-shae
the has and encryption should be
3des , sha respectivly based on ur trnasform set
good luck
if helpful Rate
godzilla0 Thu, 09/11/2008 - 03:12
I did and it's not working . . .
still getting nothing from the 871.
The 2800 is ok cause it show this :
dst src state conn-id slot status
192.168.3.11 195.53.3.154 QM_IDLE 5457 0 ACTIVE
192.168.3.11 80.34.139.242 QM_IDLE 5290 0 ACTIVE
192.168.3.11 196.12.229.218 QM_IDLE 5473 0 ACTIVE
192.168.3.11 196.12.229.218 QM_IDLE 5467 0 ACTIVE
192.168.3.11 196.12.229.218 QM_IDLE 5466 0 ACTIVE
192.168.3.11 196.12.229.218 QM_IDLE 5465 0 ACTIVE
192.168.3.11 196.12.229.218 QM_IDLE 5464 0 ACTIVE
192.168.3.11 196.12.229.218 QM_IDLE 5463 0 ACTIVE
192.168.3.11 196.12.229.218 QM_IDLE 5462 0 ACTIVE
192.168.3.11 196.12.229.218 QM_IDLE 5461 0 ACTIVE
192.168.3.11 213.27.252.202 QM_IDLE 5143 0 ACTIVE
So it is trying to stablish the connection with the 871.
I will show you where the 871 is placed:
[192.168.15.X LAN]------[871-LAN PORT-192.168.15.100]-----[871-WAN PORT-196.12.229.218]------[WAN-196.12.229.217-INTERNET ROUTER]-----[INET]
