How do you calculate 'concurrent connection' for firewall?
Sep 10th, 2008
Data center = 45Mbps circuit.
Branch offices connected to data center = 4. Total of 30 users per site. So therefore ingress traffic is 120 people.
I know that you consider about 10 TCP connections per user. If so, that is 120 x 10 = 1,200 connections.
Would you use 1,200 connections to estimate concurrent connections so that I can estimate firewall model?
Or you have another formula to estimate max # of concurrent connections?
hadbou Tue, 09/16/2008 - 05:56
  • Bronze, 100 points or more
Concurrent connections is defined as the aggregate number of simultaneous connections between hosts across the DUT/SUT, or between hosts and the DUT/SUT.The number of concurrent connections a firewall can support is just as important a metric for some users as maximum bit forwarding rate.
