Joe Clarke Wed, 09/10/2008 - 09:45
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You need to provide the whole job directory.
AECOMpete_2 Wed, 09/10/2008 - 10:10
Hi Joe,
I've attached the work order for the job. Is that what you are referring to?
-Pete
Joe Clarke Wed, 09/10/2008 - 10:18
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
No. There are a lot of other files in the 1097 job directory. I need to see all of them.
AECOMpete_2 Wed, 09/10/2008 - 10:30
Sorry, where/how can I get the data you're looking for.
Joe Clarke Wed, 09/10/2008 - 10:34
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The job directory is under NMSROOT/files/rme/jobs/swim.
AECOMpete_2 Wed, 09/10/2008 - 11:07
I assume by NSMRoot you mean the root directory of our lms installation. If so there is no NSMRoot/files/rme directory that exists. the only thing in files/ is an ipm directory.
Joe Clarke Wed, 09/10/2008 - 11:09
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
If you're on Solaris, the directory is /var/adm/CSCOpx/files/rme/jobs/swim.
Joe Clarke Wed, 09/10/2008 - 11:39
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This is telling me the devie is unable to copy the image to the TFTP server. For aecom-b1-sw, RME is trying to copy bootflash:cat4000-i9s-mz.122-25.EWA8.bin to tftp://129.98.1.85/rep_sw_9083916582808996013. Is this the correct IP address of your RME server? If you create a cat4000-i9s-mz.122-25.EWA8.bin file in the server's tftpboot directory, can you manually copy the image from the device to the server?
AECOMpete_2 Thu, 09/11/2008 - 13:54
Yes that is the correct IP. I've created a cat4000-i9s-mz.122-25.EWA8.bin file in tftpboot. Can you explain what you mean by manually copy the image from the device?
If we're relying on TFTP as opposed to RCP or SCP there shouldn't be any switch/router configuration necessary correct?
Joe Clarke Thu, 09/11/2008 - 14:01
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Okay, make sure the file has 0666 permissions, then from the switch, run:
copy bootflash:cat4000-i9s-mz.122-25.EWA8.bin tftp://129.98.1.85/cat4000-i9s-mz.122-25.EWA8.bin
You are correct that nothing additional needs to be configured on the switch.
