QSIG Caller NAME
Sep 10th, 2008
CUCM 6.1 with MGCP on a 2851
QSig trunk to Ericson MD110 switch
Cannot get caller name to work in outbound direction. It works inbound from PBX. Sends number only on outbound.
Display IE is greyed out in config
My users have their alerting name configured.
Any ideas?
gogasca Wed, 09/10/2008 - 10:22
  • Green, 3000 points or more
Check which MD110's version the customer
is running, and old version of MD110 may not interoperate well with CCM. Our
interoperability group has done extensive testing on MD110's running version BC11 and newer.
We do support calling name
Which value syou have under MD110 and in CUCM for:
ASN.1 ROSE OID Encoding
QSIG Variant
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/pbx/interop/notes/608604nt.pdf
Let sus know
ANDREW BERESFORD Mon, 09/15/2008 - 01:00
HI,
Set QSig Variant to ECMA and ASN.1 ROSE to Use Global Value (ECMA)
Restarted Call Manager service
Result is still same, no names when calling the PBX
Checked MD110 and it is running BC12
I have the same issue - with Opt81
CUCM 6.1.2 with MGCP on 2851
QSig trunk to Opt81
Cannot get Alerting ID to show up on Nortel Phone. It works from Nortel to Cisco IP Phone.
I needed to use QSIG to get Caller ID with Name to make it through the Opt81 all the way to the IP Phone (which works fine now)
ASN.1 ROSE OID Encoding Use Global Value (ECMA)
QSIG Variant ECMA (Protocol Profile 0x91)
gogasca Wed, 09/10/2008 - 11:52
Can we get detailed CCM SDI SDL traces and debug isdn q931
for an incoming call from PBX
and for an outgoing call to PBX,
please let us know
Calling number
Called number
Timestamps
Here's a call from IP Phone to Nortel - just the q931.
VSBWH1VGW3#
Sep 10 11:19:43.160 EDT: ISDN Se0/0/0:23 Q921: User RX <- RR sapi=0 tei=0 nr=33
Sep 10 11:19:44.254 EDT: ISDN Se0/0/0:23 Q921: User TX -> INFO sapi=0 tei=0, ns=33 nr=34
Sep 10 11:19:44.254 EDT: ISDN Se0/0/0:23 Q931: SETUP pd = 8 callref = 0x0003
Sending Complete
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Facility i = 0x91AA06800100820100A11702010006042B0C0900800C54617261205374657068616E
Calling Party Number i = 0x0081, '8573070998'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '916175258448'
Sep 10 11:19:44.334 EDT: ISDN Se0/0/0:23 Q921: User RX <- INFO sapi=0 tei=0, ns=34 nr=34
Sep 10 11:19:44.334 EDT: ISDN Se0/0/0:23 Q931: STATUS pd = 8 callref = 0x8003
Cause i = 0x81E4 - Invalid information element contents
Call State i = 0x06
Sep 10 11:19:44.334 EDT: ISDN Se0/0/0:23 Q921: User TX -> RR sapi=0 tei=0 nr=35
Sep 10 11:19:44.366 EDT: ISDN Se0/0/0:23 Q921: User RX <- INFO sapi=0 tei=0, ns=35 nr=34
Sep 10 11:19:44.366 EDT: ISDN Se0/0/0:23 Q931: CALL_PROC pd = 8 callref = 0x8003
Sep 10 11:19:44.366 EDT: ISDN Se0/0/0:23 Q921: User TX -> RR sapi=0 tei=0 nr=36
VSBWH1VGW3#
Sep 10 11:19:44.370 EDT: ISDN Se0/0/0:23 Q921: User RX <- INFO sapi=0 tei=0, ns=36 nr=34
Sep 10 11:19:44.370 EDT: ISDN Se0/0/0:23 Q931: ALERTING pd = 8 callref = 0x8003
Facility i = 0x9FAA068001008201008B0100A1110202010002010180084B454E54204D4446
Progress Ind i = 0x8182 - Destination address is non-ISDN
Sep 10 11:19:44.370 EDT: ISDN Se0/0/0:23 Q921: User TX -> RR sapi=0 tei=0 nr=37
VSBWH1VGW3#
Sep 10 11:19:47.491 EDT: ISDN Se0/0/0:23 Q921: User RX <- INFO sapi=0 tei=0, ns=37 nr=34
Sep 10 11:19:47.491 EDT: ISDN Se0/0/0:23 Q931: CONNECT pd = 8 callref = 0x8003
Facility i = 0x9FAA068001008201008B0100A1110202010002010280084B454E54204D4446
Connected Number i = 0x0080, '6177358448'
Sep 10 11:19:47.491 EDT: ISDN Se0/0/0:23 Q921: User TX -> RR sapi=0 tei=0 nr=38
Sep 10 11:19:47.499 EDT: ISDN Se0/0/0:23 Q921: User TX -> INFO sapi=0 tei=0, ns=34 nr=38
Sep 10 11:19:47.499 EDT: ISDN Se0/0/0:23 Q931: CONNECT_ACK pd = 8 callref = 0x0003
slongewa Wed, 09/10/2008 - 13:50
FWIW - I know BC8 will not support calling name outbound from PBX. It has something to do with the way QSig worked on the Ericsson BC8 software.
-Steve
ANDREW BERESFORD Fri, 09/12/2008 - 08:42
Thanks for the reponses. I checked and it was using the default QSig Varient (ISO protocol profile 0x9F) and the ASN.1 ROSE was set to Use Local Value.
I have changed these to refecl what is shown in the integration documentation for the Ericson, just waiting for a windows now to restart the services.
