Cisco ASA 5510 don't allow access to the LAN services from remote VPN ???
snuwan.es
I have a Cisco 5510 deployed and it's connected to a 1 Mbps leased internet line. I need to configure it for remote VPN users to access internal Exchange server and sync with email system. And they should be able to access LAn servers using the VPN. I have tried this several scenarios but still I didn't get access to to local LAN servers via VPN at any cost :( (it's connecting well and also can ping to the inside interface IP address only)
Any help would be highly appreciated.
Below is my config;
LAN is 192.168.134.0
passwd xxx
boot system disk0:/asa803-k8.bin
ftp mode passive
dns server-group DefaultDNS
domain-name domain.local
access-list abc-primary-tunnel_splitTunnelAcl standard permit 192.168.134.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip 192.168.134.0 255.255.255.0 192.168.166.0 255.255.255.128
pager lines 24
logging asdm informational
mtu management 1500
mtu inside 1500
mtu outside 1500
ip local pool primary-vpn-pool 192.168.166.1-192.168.166.100 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-603.bin
no asdm history enable
arp timeout 14400
global (outside) 101 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 101 0.0.0.0 0.0.0.0
route outside 0.0.0.0 0.0.0.0 59.133.230.21 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.134.0 255.255.255.0 inside
http 192.168.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
no crypto isakmp nat-traversal
telnet timeout 5
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
group-policy abc-primary-tunnel internal
group-policy abc-primary-tunnel attributes
dns-server value 192.168.134.1
vpn-tunnel-protocol IPSec
split-tunnel-policy tunnelspecified
split-tunnel-network-list value abc-primary-tunnel_splitTunnelAcl
default-domain value domain.local
username user1 password xxxencrypted privilege 0
username user1 attributes
vpn-group-policy abc-primary-tunnel
tunnel-group abc-primary-tunnel type remote-access
tunnel-group abc-primary-tunnel general-attributes
address-pool primary-vpn-pool
default-group-policy abc-primary-tunnel
tunnel-group abc-primary-tunnel ipsec-attributes
pre-shared-key *
class-map inspection_default
match default-inspection-traffic
33 Replies 33
singhsaju
Level 4
Level 4
your NAT 0 access-list has wrong subnet mask for the vpn pool subnet and your vpn pool has 255.255.255.0
nat 0 acl has "192.168.166.0 255.255.255.128"
change the subnet mask on NAT 0 access-list to 255.255.255.0 and then check .
Saju
Pls rate if it helps
Also add...
tnx for the replied, I'll post the results within next few minuets !!!
still not working !!! :(
Please advice, any help would be highly appreciated !!!
Can we see new config?
abc-fire(config)# sh run
: Saved
ASA Version 8.0(3)
hostname abc-fire
domain-name abcsoft.local
enable password ogafcUzB/QZE6nv9 encrypted
names
interface Ethernet0/0
nameif outside
security-level 0
ip address 89.183.250.42 255.255.255.248
interface Ethernet0/1
nameif inside
security-level 100
ip address 192.168.134.125 255.255.255.128
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
management-only
passwd 2KFQnbNIdI.2KYOU encrypted
ftp mode passive
access-list abc-primary-tunnel_splitTunnelAcl standard permit 192.168.134.0 255.255.255.128
access-list inside_nat0_outbound extended permit ip 192.168.134.0 255.255.255.128 192.168.166.0 255.255.255.128
pager lines 24
mtu management 1500
mtu inside 1500
mtu outside 1500
ip local pool vpn-primary-pool 192.168.166.1-192.168.166.100 mask 255.255.255.0
arp timeout 14400
route outside 0.0.0.0 0.0.0.0 89.183.250.41 1
http server enable
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
default-domain value abcsoft.local
username user1 password yhK1oj.zZzQLnCkB encrypted privilege 0
address-pool vpn-primary-pool
pre-shared-key *
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:xxx
: end
abc-fire(config)#
in the new config you have still not changed the subnet mask in the Nat0 access-list that i asked earlier.
changed mask to 255.255.255.0 it just now !!! but still no luck !
Do you see "hitcounts" increasing on access-list inside_nat0_outbound ?
check and post result of
show access-list inside_nat0_outbound
abc-fire(config)# show access-list inside_nat0_outbound
access-list inside_nat0_outbound; 1 elements
access-list inside_nat0_outbound line 1 extended permit ip 192.168.134.0 255.255.255.128 192.168.166.0 255.255.255.128 (hitcnt=0) 0x1eaae319
Your access-list still does not reflect the change , also why have you changed 192.168.134.0 's subnet mask to 255.255.255.128 ??
your access-list should look as following:
access-list inside_nat0_outbound line 1 extended permit ip 192.168.134.0 255.255.255.0 192.168.166.0 255.255.255.0
ok i have removed 128 subnets and now it's all coming with 255.255.255.0 mask !!
but still no luck ! :( but i can ping 192.168.134.125 which inside interface ...!!!
