Packet Tracer
Answered Question
Sep 10th, 2008
Will the packet tracer work if a interface is down? My understanding is that I can use this to test my configuration before bringing everything up. Is this correct?
Thank you,
Travis
Correct Answer by suschoud about 8 years 7 months ago
Yes Travis,
You understanding is correct.Just tried that in lab before posting....Best of luck!!
Sushil
Overall Rating: 5 (1 ratings)
Correct Answer
suschoud Wed, 09/10/2008 - 11:27
  • Gold, 750 points or more
Yes Travis,
Sushil
SuburbanHealth Wed, 09/10/2008 - 11:31
I guess I have a problem then. I will open a new post for that problem.
Thank you,
Travis
suschoud Wed, 09/10/2008 - 12:58
Hi ,
Looks like I had my inside interface down and outside up when I initiated packet tracer from inside to outside.....
I think because of outside interface being down,the route outside command is not working......
If you do a " sh route ",you would not see it as outside interface is down....
suschoud Wed, 09/10/2008 - 12:59
Just attach a cable to the outside interface and try packet tracer again....
