09-10-2008 11:49 AM - edited 03-11-2019 06:42 AM
Hi - We have a NEC VOIP phone system that uses SIP port 5080 not the default port 5060. Can the inspect sip be changed on the Cisco ASA 7.2. Firewall like fixup could be changed on the PIX Firewall?
09-10-2008 11:58 AM
Here you go:
ASA-5510-8x(config)# policy-map global_policy
ASA-5510-8x(config-pmap)# class inspection_default
ASA-5510-8x(config-pmap-c)# no inspect sip
ASA-5510-8x(config-pmap-c)# exit
ASA-5510-8x(config-pmap)# exit
ASA-5510-8x(config)# class-map mymap
ASA-5510-8x(config-cmap)# match port tcp eq 5080
ASA-5510-8x(config-cmap)# exit
ASA-5510-8x(config-pmap)# class mymap
ASA-5510-8x(config-pmap-c)# ins
ASA-5510-8x(config-pmap-c)# inspect sip
ASA-5510-8x(config-pmap-c)# end
PLease rate if helpful
Sushil
09-10-2008 12:11 PM
Thanks Sushil, you are really fast with your post! I will try this out.
Paul.
