AP1130 in H-REAP mode unable to join to WLC4402
Sep 10th, 2008
I'm trying to solve an AP 1130 (in H-REAP mode) that didn't manage to connect to the controller (WLC4402):
%LWAPP-3-CLIENTERRORLOG: Join Timer: did not recieve join response (controller - WLC4402)
%LWAPP-3-CLIENTERRORLOG: Set Transport Address: no more AP manager IP addresses remain
%SYS-5-RELOAD: Reload requested by LWAPP CLIENT. Reload Reason: DID NOT GET JOIN RESPONSE.
%LWAPP-5-CHANGED: LWAPP changed state to DOWNXmodem file system is available.
any ideas?
jeff.kish Wed, 09/10/2008 - 13:18
What do you mean that the 1130 is in H-REAP mode? Was it connected to the controller before, and now it can't connect?
Generally, the "no more AP manager IP addresses remain" message means that your access point can't find the AP Manager Interface on the controller. Make sure that it has access to that IP address. Check to see whether it's configured properly - it should be on the same subnet as your management interface.
Scott Fella Wed, 09/10/2008 - 13:58
Post your show run-config so we can see how you are setting the wlc up.
arun.k Thu, 09/11/2008 - 16:26
check your firewall rules ensure the LWAPP ports are open. Otherwise how are your AP's getting their ip address? static, or DHCP? make sure evertyhing clean in that area and check your interface ip's.
Trending Topics - Security & Network
