Voice problem with two WAN router connection
Sep 10th, 2008
hi
i have a 2811 router with two wan conecction to site central, but different routers, 7500 and 7200.
I have voice problem in one direction, the user dont lisen the other user,
the load balancing EIRGP is activated in all routers.
This maybe cause the voice problem?
a.gooding Wed, 09/10/2008 - 14:42
  • Bronze, 100 points or more
normally from my experience its always a routing issue causing this. is your gateway MGCP or H323. either way did you bind to the appropriate interface?
eljose_lol Thu, 09/11/2008 - 05:25
i am using h323 gateway, and i think thats a summary problem with eigrp,
Marwan ALshawi Thu, 09/11/2008 - 06:21
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
hi Jose
loadbalnacing and any kind of routing voice use with multiple path sometimes cause problems such as jitter because of delay varaition with data u dont feel it with voice some time packet arrive befor other and the lead to this issue
try to use one path if solved then u have to change ur routing topology
if helpful Rate
eljose_lol Fri, 09/12/2008 - 05:33
hi bro
thx for the reply,i thonk same, but with a route map can solve this problem? is only one way communication.
Marwan ALshawi Fri, 09/12/2008 - 06:14
u could match any ip traffic from Voice network go to one router as next hope and use the other in case of the main one down
for exaple lets say ur voice network is 10.1.1.0/24
access-list 1 permit 10.1.1.0 0.0.0.255
access-list 1 deny any
the deny statment in the end to include only voice network in the route map matching and other traffic will be excluded
route-map voice permit 10
match ip address 1
set next-hop [first router]
route-map voice permit 20
good luck
if helpful Rate
