IP Phone 7961: Factory Reset
Sep 10th, 2008
I performed a factory reset on 1 of my phones and I did not see the option to maintain the network configurations. Now the phone keeps rebooting probably because it cant find the CM server.
How can I stop the phone from rebooting so i can access the menus to specify the CM servers?
Overall Rating: 3 (4 ratings)
Jaime Valencia Wed, 09/10/2008 - 17:56
  • Cisco Employee,
  • Hall of Fame,
    2011
if you cannot stop it then configure a DHCP server to get the info into the phone
java
if this helps, please rate
barneb011 Thu, 09/11/2008 - 08:48
Thanks...that was too easy. I wonder why TAC couldnt give me that answer???
Jaime Valencia Thu, 09/11/2008 - 12:42
  • Cisco Employee,
  • Hall of Fame,
    2011
haha, not sure. maybe lack of imagination?? =)
java
ramlah0000 Fri, 09/03/2010 - 06:06
please i need your help with 7961. i did reset my phone to factory reset and keeps rebooting, i did see that u said (if you cannot stop it then configure a DHCP server to get the info into the phone) how can i do that Pleaaaaaaaaaase
