Security Device Manager (SDM) download for ISR 1841
Sep 10th, 2008
I'm studying for CCNA. How do I download the application on to my computer? And how do I confirm that it is on my 1841?
Mark Yeates Wed, 09/10/2008 - 16:32
Cliff,
You can download SDM from the link below. SDM can be installed on your PC, router or both. If you choose to install it to flash on your router you can issue the "show flash:" command and you will see many additional SDM files. I would recommend reading the release notes and documentation carefully and get a firm understanding of the GUI and it's features. You will also need to add some commands for SDM functionality found in the documentation.
http://www.cisco.com/cgi-bin/tablebuild.pl/sdm
HTH,
Mark
