09-10-2008 05:19 PM - edited 03-03-2019 11:29 PM
What is the command to see what size memory card is installed on a 6500 line card (not to be confused with the SP or RP memory)
Thanks!
Matt
09-16-2008 04:25 PM
Following URL will help you:
http://www.cisco.com/en/US/docs/routers/7600/install_config/ES20_config_guide/SRC1/baldcsm.html#wp1049270
Log in to Community
