09-10-2008 05:23 PM - edited 03-03-2019 11:29 PM
Is there an acceptable amount of errors on a T-1? For example if you have a point-to-point Full T1 with a remote site and it accumulates 50 or 100 CRC and frame errors per day, but usually only in one direction is this ok? Is there such a thing as normal errors on a T-1, or can some even a few errors be expected?
09-10-2008 05:53 PM
Hi, from my experience, it should be error free. Have you contact your telco on this problem?
jerry
09-11-2008 04:07 AM
Jerry,
We have contacted the telco and had intrusive testing performed. Of course the telco says everything is clean, but you're sayting I should never have any errors, right?
09-11-2008 04:09 AM
Jerry,
Would something like this amount per day cause an issue?
4 input errors, 4 CRC, 0 frame, 0 overrun, 1 ignored, 0 abort
09-11-2008 05:03 AM
Just a question, are you receiving the same amount of errors on the remote end?
You can also try to swap out the T1 interface card on your router to see if the error goes away.
jerry
09-10-2008 08:59 PM
Hello!
For me 50 CRC errors / day is quite a lot. Normal they should be 0, but it's ok also now and then 5-10 errors due to line deprecation or possible problems on the path. If your equipments are OK you should have a talk with your provider.
Cheers,
Calin
