active directory integration with CMBE
Sep 10th, 2008
is it posible to integrate active directory with CMBE
Overall Rating: 1 (1 ratings)
Jaime Valencia Thu, 09/11/2008 - 06:32
no, it's not possible. CUCMBE is ALL IN ONE BOX solution. you cannot integrate any LDAP directory with it
if this helps, please rate
Michael Owuor Thu, 09/11/2008 - 07:57
To add to the information Java provided, if directory integration is something you really need, you could wait for the release of CUCMBE 7.0, which has LDAP Directory Sync as one of the new features that has been added.
Essentially, the CallManager will be able to be integrated with an external LDAP directory such as MS AD, to synchronize corporate directory data. Unity Connection will not not know that the user information came from LDAP, but will instead view the users as CallManager users.
See the documentation of this new CUCMBE feature here:
