09-10-2008 11:26 PM
Please find attached the config of ASA and error on remote pc while connecting through remote vpn client software.
Is there anything wrong with config?
Tried changing hash from md5 to sha and vice-versa.
Reg,
Sushil
09-11-2008 01:52 AM
Sushil,
The error is pretty simple "Hash verification failed... may be configured with invalid group password."
on the remote client make sure that the "Name" in the group authentication is set to "testgroup" and the password matches what you have configured in "tunnel-group testgroup ipsec-attributes
pre-shared-key *"
HTH>
09-11-2008 02:14 AM
Thanks Andrew it was wrong password and group.
09-11-2008 02:30 AM
Sushil,
To answer your questions:-
1) Yes you are configured for 2 factor authentication, Group UI & PWD, and UID & PWD
2) You can just add :-
isakmp ikev1-user-authentication none
HTH>
09-11-2008 03:05 AM
np - glad to help.
