iPhone: which IKE proposal and which SA for cert auth
Sep 11th, 2008
Dear all,
does anyone know which IKE proposal and which SA I need to manufacture to achieve certificate authentication with iPHONE and a VPN3000?
I mean technically it must work, isn't it?
htarra Wed, 09/17/2008 - 11:20
Under : Configuration\Policy Management\Traffic Management\SAs
You will find the IPSec Proposals, not IKE. For IKE proposals, you need to go to :
Configuration | Tunneling and Security | IPSec | IKE Proposals
There you need to check if your proposal is in active proposals list or not. If not, you have to add it to Active Proposals.
Hope this helps.
