09-11-2008 01:38 AM - edited 03-11-2019 06:42 AM
Hi, Freiends
Can you please forward procedure for configuring fulltime vpn tunnel between PIX515 to ASA firewall.
Thank you very much for support.
Solved! Go to Solution.
09-11-2008 02:02 AM
Francisco,
Yes he would need a cco login - well pointed out.
Nice find on "free" page!
Andrew.
09-11-2008 01:47 AM
09-11-2008 01:54 AM
Andrew, i think he will need CCO login to access the links.
see http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00805a87f7.shtml No CCO login required.
The ASA 5500 series version 7.x/8.x runs the same software seen in PIX version 7.x/8.x
Francisco
09-11-2008 02:02 AM
Thanks andrew|Francisco for your reply.
very snappy links for refrence.
Thx Again.
09-11-2008 02:02 AM
Francisco,
Andrew.
