Multiple_VPN clients connection problem
I have set up an easy vpn server on Pix 515E (IOS Version 6.2(2)).I can connect to it from anywhere and another user can also connect from different location.(That is Multiple VPN clients can only connect from different locations)
The problem I have now is I can not connect multiple VPN clients from the same LAN. I can only make one VPN client connection at a time.
I would be very grateful if somebody could have a look at my config and advise me. Attahched is the Easy VPN configs
Kind regards,
Hello Andrew,
Sorry for the delay, I have attached the config with the remote access profile settings.
What I want to know is, "is it possible to make multiple VPN clients connections from one LAN (let say from your office LAN)to Easy VPN server (PIX 515E ver 6.2(2)?".
If so what command can make this work for me.
Hope to hear from you soon.
