Cisco Call Manager gateway registration MGCP
Sep 11th, 2008
Hi, I have problem with registration.. I have 2 box of ISDN , one box is connected to port 0/2/1 and he is successful register with call manager but second box on port 0/2/0 can not register it is allways unregister, in debuging i see this:
mgcp_msg_ack:6065,Updating (*)=172.17.1.95
*Sep 11 11:16:43.851: *:NO-MATCH, 172.17.1.95:2427, 172.17.1.95
*Sep 11 11:16:43.851: BRI/S0/*:NO-MATCH, 172.17.1.95:2427, 172.17.1.95
*Sep 11 11:16:43.851: BRI/S0/SU2/*:NO-MATCH, 172.17.1.95:2427, 172.17.1.95
*Sep 11 11:16:43.851: BRI/S0/SU2/P1/*:NO-MATCH, , 172.17.1.95
*Sep 11 11:16:43.851: BRI/S0/SU2/P1/1:NO-MATCH, 172.17.1.95:2427, 172.17.1.95
*Sep 11 11:16:43.851: BRI/S0/SU2/P1/2:NO-MATCH, 172.17.1.95:2427, 172.17.1.95
*Sep 11 11:16:43.851: BRI/S0/SU2/P0/*:NO-MATCH, , 172.17.1.95
*Sep 11 11:16:43.879: MGCP Packet received from 172.17.1.95:2427--->
AUEP 1136 BRI/S0/SU2/P0/[email protected] MGCP 0.1
interface BRI0/2/0
no ip address
isdn switch-type basic-net3
isdn overlap-receiving
isdn point-to-point-setup
isdn incoming-voice voice
isdn skipsend-idverify
isdn bind-l3 ccm-manager service mgcp
isdn static-tei 0
end
interface BRI0/2/1
no ip address
isdn static-tei 0
What i need to do to get bouth box register with CCM. tnx
Michael Owuor Thu, 09/11/2008 - 04:48
  • Cisco Employee,
Hi Anis,
Can you confirm that in CallManager, port 0/2/0 has been configured as an endpoint separate from endpoint 0/2/1? Can you post the screenshot of the configuration of port 0/2/0?
Michael.
aniss12345 Thu, 09/11/2008 - 05:30
I hope that this will help you... i will post more show command:
ccm-manager mgcp
mgcp
mgcp call-agent 172.17.1.95 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp rtp payload-type g726r16 static
mgcp profile default
service mgcpapp
service mgcpapp
combisbh-sar_rt01#show running-config | include ccm
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 172.17.1.95
ccm-manager config
whanson Thu, 09/11/2008 - 05:44
can you send the whole config of the gateway?
aniss12345 Thu, 09/11/2008 - 05:57
I will copy part of configuration for CCM and CCME, on the same router i have CCM and CCME, one ISDN box which working 0/2/1 is CCM, other interface bri 0/2/0 it is CCME , so when i want register interface 0/2/0 for CCM i put 2 command :
isdn static-tei 0
but it is still unregister i am not sure why ?
resource policy
clock timezone Warsaw 1
network-clock-participate wic 2
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip cef
voice-card 0
voice service pots
voice class codec 100
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
voice class h323 1
h225 timeout tcp establish 3
h225 timeout setup 25
voice class dualtone-detect-params 90
freq-max-power 6
freq-min-power 25
freq-power-twist 15
freq-max-delay 16
cadence-variation 8
voice translation-rule 10
rule 1 /\(.*\)880$/ /1070/
rule 2 // // type any unknown
voice translation-rule 11
rule 1 /\([7-9].\)/ /10\1/
voice translation-profile Ulaz-4769XX
translate called 11
voice translation-profile unutra
translate called 10
interface FastEthernet0/0.10
description [CISCO IP PHONE]-
encapsulation dot1Q 10
ip address 172.17.2.1 255.255.255.192
ip virtual-reassembly
no snmp trap link-status
interface BRI0/2/0
no ip address
isdn static-tei 0
interface BRI0/2/1
no ip address
isdn static-tei 0
control-plane
voice-port 0/2/0
compand-type a-law
voice-port 0/2/1
compand-type a-law
ccm-manager mgcp
ccm-manager config
mgcp
mgcp sdp simple
dial-peer voice 100 pots
destination-pattern 0T
direct-inward-dial
port 0/2/0
dial-peer voice 1 pots
translation-profile incoming unutra
incoming called-number .T
no digit-strip
direct-inward-dial
port 0/2/0
forward-digits 0
dial-peer voice 2 pots
translation-profile incoming Ulaz-4769XX
incoming called-number [7-9].
direct-inward-dial
port 0/2/1
dial-peer voice 3 pots
destination-pattern 9T
direct-inward-dial
port 0/2/1
dial-peer voice 4 pots
service mgcpapp
direct-inward-dial
port 0/2/1
dial-peer voice 5 pots
service mgcpapp
direct-inward-dial
port 0/2/0
gateway
timer receive-rtp 1200
credentials
telephony-service
load 7970 term71.default.loads
load 7912 CP7912050000SCCP041115A
max-ephones 30
max-dn 50
ip source-address 172.17.2.1 port 2000
auto assign 20 to 30 type CIPC
timeouts interdigit 3
url information http://172.17.1.1/ccme.html
time-format 24
date-format dd-mm-yy
create cnf-files version-stamp Jan 01 2002 00:00:00
max-conferences 4 gain -6
dn-webedit
time-webedit
secondary-dialtone 0
login timeout 120 clear 23:00
xmltest
Michael Owuor Thu, 09/11/2008 - 06:05
  • Cisco Employee,
Thanks for posting the configuration. After adding the two commands to register 0/2/0 as an MGCP endpoint, you might have to restart the MGCP process on the router by doing:
no mgcp
mgcp
If you could capture the output of debug mgcp packet when resetting the MGCP process that would be great.
Also, can you confirm that the configuration on the router has 'ip domain-name' statement.
Michael.
aniss12345 Thu, 09/11/2008 - 06:22
Thanx that is, when i put no mgcp and mgcp
its work!
Michael Owuor Thu, 09/11/2008 - 06:27
  • Cisco Employee,
Excellent. Thanks for the update.
Michael.
aniss12345 Thu, 09/11/2008 - 06:00
isdn static-tei 0
resource policy
no mmi pvc
ip cef
voice-card 0
voice service pots
voice class h323 1
freq-max-power 6
freq-min-power 25
freq-power-twist 15
freq-max-delay 16
cadence-variation 8
translate called 11
translate called 10
interface BRI0/2/0
no ip address
isdn static-tei 0
interface BRI0/2/1
no ip address
isdn static-tei 0
control-plane
voice-port 0/2/0
compand-type a-law
voice-port 0/2/1
compand-type a-law
ccm-manager mgcp
ccm-manager config
mgcp
mgcp sdp simple
direct-inward-dial
port 0/2/0
no digit-strip
direct-inward-dial
port 0/2/0
forward-digits 0
direct-inward-dial
port 0/2/1
direct-inward-dial
port 0/2/1
service mgcpapp
direct-inward-dial
port 0/2/1
service mgcpapp
direct-inward-dial
port 0/2/0
gateway
credentials
telephony-service
max-ephones 30
max-dn 50
time-format 24
dn-webedit
time-webedit
xmltest
