Failed to create cert pipe
Sep 11th, 2008
I am using Cisco VPN Client 5.0.03.0560 and when I am trying to connect it says :
46 08:57:31.733 09/11/08 Sev=Info/6 CERT/0x63600034
Attempting to sign the hash using the private key under Windows Vista.
47 08:57:31.733 09/11/08 Sev=Warning/2 CERT/0xE3600001
Failed to create cert pipe.
Once that happens I start to get failurs on the connect and I am also seeing IKE failurs. Then the client just reports not connected. Does anyone have any ideas on this?
mattwise1 Thu, 09/11/2008 - 10:28
When I try to open the URLs you provided I get "Forbidden File or Application"
mattwise1 Fri, 09/12/2008 - 04:04
I actually do not have access to our ASA. I am using a custom built image and I was wondering if there are any group policy settings or anything that would cause this.
The reason I ask is on a normal Windows XP/Vista system the client connects fine so I know it isn't our ASA configuration.
