VPN Design Questions
Sep 11th, 2008
We just purchased a small company and we need to provide a vpn tunnel between the two of us. They currenty have a 6+ year old netscreen firewall for vpn/security. My thoughts were either place a cisco 1841 inside their firewall to create a tunnel with us, or replace their current firewall with a low end ASA. Any thoughts?
Richard Burts Thu, 09/11/2008 - 07:58
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jason
There may be some other aspects of your situation of which we are not aware. But based on what you describe about acquisition of a small company I assume that you want to integrate that small company into your infrastructure. And to do that some LAN to LAN VPN which also had the ability to run a routing protocol between the remote site and your main site would seem to be needed. I believe that an 1841 inside their firewall would accomplish this while just replacing their old firewall with an ASA would not.
Rick
