WLC Client details> Policy Manager State
Answered Question
Sep 11th, 2008
on the controller under the client details, what is the policy manager state?
my client says it's RUN. What does thsi mean?
Correct Answer by bbxie about 8 years 6 months ago
it will only show the AUTH that the client need to pass before it can work normally, for example, if you configure the WLAN to use WEB-authentication, then before the client pass web-auth, it will show WEBAUTH_REQD, but will not show things like dhcp or 802.11 association.
Overall Rating: 5 (3 ratings)
bbxie Thu, 09/11/2008 - 21:51
  • Silver, 250 points or more
The Cisco UWN security solution bundles potentially complicated Layer 1, Layer 2, and Layer 3 802.11 Access Point security components into a simple policy manager that customizes system-wide security policies on a per-WLAN basis.
Before a client passed the authentication, policy manager state will show you what kind of security will needed, for example, if this WLAN is configured with 802.1x authtication, and the client associated with this WLAN but have not passed 802.1X authentication, then the policy manager status will be 8021X_REQD; if the client had passed the authentication and work normally, then the policy manager status will be RUN
thompso7540 Fri, 09/12/2008 - 04:02
will it show me other things besides 802.1x?
like dhcp or 802.11 association?
Correct Answer
bbxie Fri, 09/12/2008 - 04:24
kfarrington Mon, 09/28/2009 - 06:53
Guys, What does "Policy Manager State" START mean?
Many thx
Ken
Florin Barhala Mon, 03/24/2014 - 07:04
  • Bronze, 100 points or more
Hi guys,
I've the same question:  What does "Policy Manager State" START mean?
Here is what I found while searching:
START -- Meaning the client is starting the process to get on the network
802.1x_REQ - Means the client is failing authentication
DHCP_REQ - Means the client is having a IP issue
RUN - Means lift is good
Now, I would ask what does a client stuck in START mean?
What state should a client stay if MAC Filtering is enabled, and its MAC is not present on the allowed MAC list?
Sandeep Choudhary Mon, 03/24/2014 - 08:08
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Wireless
Hi Florin,
Yes you are right,
If Policy Manager State is START means:
stuck in Start means client did completed the authentication which is requires according to WLAN configuration.(Mac filtering)
It will be in START state.
Dont forget to rate helpful posts
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
