searching for new product
Sep 11th, 2008
hi there,
We have 3500 switches in my network and it is End of life and support also. now we are planning for chassis base layer 2 switches.
we have 1000 ports network , so please suggest me which chassis are available with cisco
satish_zanjurne Thu, 09/11/2008 - 07:03
I will always suggest with 6500 chassis , although other chassis like 4500 are availble.
I tell you with proper configuration, 6500 chassis fits at any layer starting from access,distribution,core.
You get all options for WAN , LAN & Security.
You get enoigh port density.
For IP Telephony/VoIP , this would be ideal switch..
HTH..rate if helpful...
Joseph W. Doherty Thu, 09/11/2008 - 10:00
The 4500 chassis series using the various sup-II supervisors offer L2, but most of the newer variants supervisors also support L3 switching, such as the 4500 with the sup-IV/V/6, the 6500 series with the sup32/sup32-PISA/sup720/VSS. There's also the Nexus 7000 series, but its oriented for high density 10 gig.
Besides chassis switches, you might also consider the stackable 3750 and 3750-E.
