EAP-TLS with WLC 4404 (Which Layer 2 option do I choose)
Answered Question
Sep 11th, 2008
Hi All,
I want to setup a WLAN that uses EAP-TLS.
WiFi PC <-----> LWAP <------> WLC <----> Radius Server
Under the Layer 2 tab for security on the WLC what option do I use for the following :-
Layer 2 Security (I am assuming WPA+WPA2 as that what the laptops will be using)
Auth Key Mgmt ?
I am a bit confused by the 802.1x in both of these fields, one for Layer two Security and one for Auth Key Mgmt?
Many thx indeed guys,
Ken
Correct Answer by Scott Fella about 8 years 9 months ago
You would choose Layer 2 Security: WPA+WPA2
Then on the WPA+WPA2 Parameters choose WPA2 Policy with WPA2 Encryption. Under Auth Key Mgmt choose 802.1x.
Now if you require the use of WPA Policy, then also choose TKIP for that.
Then for your AAA Server tab choose your radius servers.
That is it.
Overall Rating: 5 (1 ratings)
Correct Answer
Scott Fella Thu, 09/11/2008 - 13:12
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
That is it.
kfarrington Thu, 09/11/2008 - 23:25
Thx fella :)
I chose 802.1x+cckm for fast roaming. Any caveats to this, as we will be testing 7921 phones on this test WLAN also?
Many thx
Ken
Scott Fella Fri, 09/12/2008 - 03:25
  • Hall of Fame,
    2017 Wireless
It shouldn't be a problem. Here is the 7921 delpoyment guide that you should also look at.
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7921g/6_0/english/deployment/guide/7921dply.pdf
Scott Fella Fri, 09/12/2008 - 03:40
  • Hall of Fame,
    2017 Wireless
Trending Topics - Security & Network
