Primary/secondary RADIUS server
Answered Question
Sep 11th, 2008
  • Silver, 250 points or more
Hey all,
I've been trying to discover for a while how primary and secondary RADIUS servers work on WLC 4400s. If the primary RADIUS server goes down, and the secondary is used, at what point does the controller go back to the primary once it's back up? Does it wait until the secondary goes down, or does it immediately switch back to the primary once it becomes available?
Thanks in advance!
Jeff
Correct Answer by Scott Fella about 8 years 7 months ago
On 4.2 and previous versions, if the primary goes down, then the secondary is used until the secondary is not available. So if you want to froce the primay to be the radius server to be used, reboot the secondary. Then the tertiary then back to the primary. 5.0 has a feature in which you can set a keep alive so that when the primary comes back up, the primary will be used again. 5.0 code in not a good code version though.
Overall Rating: 5 (2 ratings)
Correct Answer
Scott Fella Thu, 09/11/2008 - 09:25
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
jeff.kish Thu, 09/11/2008 - 10:57
I seem to hear a lot about how bad 5.0 code is. Either way, that definitely helps a lot. Thanks!
Robert Rowland III Thu, 09/11/2008 - 13:03
5.1 is out for a month.
I have 700 radios on it. No problems so far and it has corrected issues I saw with 5.0.
Especially with voice.
Scott Fella Thu, 09/11/2008 - 13:14
  • Hall of Fame,
    2017 Wireless
That is good to know.... we are still testing that code. What are you running 5.1 on? WiSM's and type of AP's?
Trending Topics - Security & Network
