09-11-2008 08:53 AM - edited 03-11-2019 06:43 AM
I am getting an erro when trying to open the ASDM to manage my 5520. I did upgrade my Java recently so I tried removing and reinstalling but I get the same error. Weird thing is that I am getting the same error from any computer I try, even with different versions of Java. Java Console error is below:
ASDM Application Logging Started at Thu Sep 11 11:51:46 CDT 2008
Local Launcher Version = 1.5.30
Local Launcher Version Display = 1.5(30)
OK button clicked
Trying for ASDM Version file; url = https://10.x.xxx.x/admin/
Server Version = 6.1(3)
Server Launcher Version = 1.5.30, size = 319488 bytes
Launcher version checking is successful.
invoking SGZ Loader..
Cache location = C:/Users/xxxx/.asdm/cache
java.lang.NumberFormatException: For input string: "C"
at java.lang.NumberFormatException.forInputString(Unknown Source)
at java.lang.Integer.parseInt(Unknown Source)
at mo.bv(DashoA10*..:4084)
at mo.b0(DashoA10*..:416)
at mo.<init>(DashoA10*..:285)
at com.cisco.pdm.PDMApplet.start(DashoA10*..:159)
at com.cisco.nm.dice.loader.r.run(DashoA19*..:410)
Exception in Starting Main window
Exception in thread "SGZ Loader: launchSgzApplet" java.lang.NullPointerException
at com.cisco.pdm.PDMApplet.start(DashoA10*..:165)
Thanks for your help...
09-11-2008 10:18 AM
I did some research and found this Micorosft uninstall utility.
Please go to the link below and try this-
http://support.microsoft.com/kb/290301
and download the 'uninstall utility '.Use Windows Install Cleanup utility which would enable you to clear the registry entries of the old version.Then manually delete the ADSM folder under C:\Program Files\Cisco Systems and then you should be able to install the new version by going
X.x.x.x would be the ip address of ASA.
Do rate helpful posts. :)
Sushil
09-11-2008 10:47 AM
I am not sure what using that tool would do, it is happening on ANY computer i try to connect from. I am able to connect to other ASA firewalls with no problem so the issue appears to be something the ASDM is reading from this particular ASA.
09-11-2008 10:52 AM
Absolutely,
I was assuming these symptoms and you just confirmed it.
Basically,you will go for a fresh install which works everywhere ( for every asa ).
Try it on one comp.,if works ,try on others too.
Sushil
10-21-2008 12:43 PM
I am getting the same error. I followed your suggestion, but reinstalling changed nothing.
ASDM Application Logging Started at Tue Oct 21 13:41:32 GMT-07:00 2008
Local DM Launcher Version = 1.5.22
Local DM Launcher Version Display = 1.5(22)
OK button clicked
Cache location = C:/Documents and Settings/eric-administrator/.asdm/cache
Checking the DM Launcher Version; url = https://xyz/admin/
Server DM Version = 6.0(2)
Server DM Launcher Version = 1.5.22, size = 318464 bytes
DM Launcher version checking is successful.
Exception in thread "SGZ Loader: launchSgzApplet" java.lang.NumberFormatException: For input string: "1 year 2"
at com.cisco.pdm.Check.h(DashoA10*..:1339)
at com.cisco.pdm.Check.c(DashoA10*..:842)
at com.cisco.pdm.Check.a(DashoA10*..:442)
at com.cisco.pdm.PDMApplet.start(DashoA10*..:124)
10-21-2008 02:44 PM
This tells me f/w uptime is 1 year 2.
there is a known issue with asdm when uptime is more then one year.The workaround for now is to reload the asa so that uptime gets back to zero.
Sushil
10-22-2008 12:53 AM
This is your problem CSCsr89144
