License ASA5510-sec-bun-k9 with a k8 image
Sep 11th, 2008
My company buyed an ASA5510-sec-bun-k9
but when I do show ver I have this output : asa707-k8.bin
I am very surprised, I have to use PAK ?
or I have to upgrade the image?
Licensed features for this platform:
Maximum Physical Interfaces : Unlimited
Maximum VLANs : 25
Inside Hosts : Unlimited
Failover : Active/Standby
VPN-DES : Enabled
VPN-3DES-AES : Enabled
Security Contexts : 0
GTP/GPRS : Disabled
VPN Peers : 150
This platform has an ASA 5510 Security Plus license.
Overall Rating: 5 (2 ratings)
Richard Burts Thu, 09/11/2008 - 09:50
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Enrique
I believe that you are ok and do not need to do anything. It is perhaps confusing but there appears to be a difference between k8 and k9 in the licensing (k8 gets DES but not 3DES/AES while k9 gets 3DES/AES) and you have the k9 license (since 3DES/AES is enabled). However in the software there is only the k8 image file. I checked in the software download pages on the Cisco web site and there are no k9 images listed, only k8 images.
So I believe that your company received what it purchased and there is no need to do anything special.
Rick
ebotas Thu, 09/18/2008 - 20:30
Is not supposed to have 250 VPN Peers? and the interfaces should be 2GE 3 FE ?
I have the same part number as proteksa2006 with same versions OTB
