ACE Loadbalancing-TFTP server
Sep 11th, 2008
This is regarding the ace-TFTP server load balancing, the ace will load balance on port 69.We have tried to do the same, its seems to the ACE getting the TFTP request but not able to reply back to the client, also we are also probing the same on port number 69.If any one face this issue, please share.
Regds
Saji k.s
Doha
Syed Iftekhar Ahmed Thu, 09/11/2008 - 22:02
  • Blue, 1500 points or more
TFTP is little complex. It uses two flows and unfortunately we dont have tftp inpect/fix available in ACE
1) Client initiate the session using UDP flow to port 69 from a random port, lets say X
2) server replies with data, opening a new UDP flow towards the client. Server's source port is random, while destination port for this response is X .
3) Now ACE has no clue about TFTP flows (lack of tftp fix/inspect), hence client will recieve tftp response from Real server directly.Since the response is not from VIP (where client sent the request),Client will drop the response
For TFTP we will have to source nat the server response using VIP (where the initial request was sent).
I have written a sample config keeping the above tftp process in mind and I think it will work.
In this config vlan 20 is the client VLAN where VIP is defined and VLAN 30 is the server vlan where the REAL tftp servers reside.
Since this TFTP workaround requires Source NAT using VIP address , this config will only work for ACE 2.X code ( In previous codes using VIP for source NAT was not supported)
Try it if you can
rserver host tftp-server1
ip address 10.10.10.101
inservice
rserver host tftp-server2
ip address 10.10.10.102
inservice
serverfarm host TFTP-SFARM
rserver tftp-server1
inservice
rserver tftp-server2
inservice
class-map match-any TO-TFTP-VIP
description class-map for client to TFTP VIP traffic
match virtual-address 192.168.0.100 udp eq 69
class-map match-any FROM-TFTP-REAL
description class-map from tftp server to client
match virtual-address 0.0.0.0 0.0.0.0 udp eq any
policy-map type loadbalance first-match TFTP-POLICY
class class-default
serverfarm TFTP-SFARM
policy-map multi-match CLIENT-VLAN-VIPS
class APP1-VIP-CLASS
loadbalance vip inservice
loadbalance policy APP1-POLICY
loadbalance vip icmp-reply
policy-map multi-match SERVER-VLAN-VIPS
class FROM-TFTP-REAL
nat dynamic 100 vlan 20
interface vlan 20
description CLIENT-VLAN
ip address 192.168.0.1 255.255.255.0
access-group input anyone
access-group output anyone
nat-pool 100 192.168.0.100 192.168.0.100 netmask 255.255.255.255
service-policy input CLIENT-VLAN-VIPS
no shutdown
interface vlan 30
description SERVER-VLAN
ip address 10.10.10.254 255.255.255.0
service-policy input SERVER-VLAN-VIPS
no shutdown
jonathan.kirkness Wed, 05/26/2010 - 07:19
Has anyone been successful with load balancing the TFTP requests on ACE?
With the CSS, this can be done with a source group.
