WAAS Central manager configuration
Sep 11th, 2008
I'm trying to get my Central Manager going but I'm finding the documentation very confusing. I installed the image (WAAS- and when it comes up the first time, the appliance is in application-accelerator mode. So I change the device mode to central-manager, and reboot.
When it comes back up, it's in the correct state. However, it won't allow me to connect to it through port 8443. My routing is fine as I can get to the appliance and back no problem, but when I try to https://x.x.x.x:8443, it goes nowhere.
Also, when I have it configured as application-accelerator, I can log on through port 8443 no problem.
Any ideas? and would anyone point me to some quality documentation on the setup?
The docs i'm currently using are:
darkid123 Thu, 09/11/2008 - 10:23
Never mind...found it!
"cms enable" needs to be entered to start the server.
dstolt Thu, 09/11/2008 - 11:17
you got it...and if for some reason the GUI isn't working, first thing to check is if CMS is stopped.
Good luck!
