IOS to CATOS migration
Sep 11th, 2008
hello folks
I have 5 distribution/core switches running CatOS. I am trying to migrate them into IOS, infact changing whole supervisor engine with IOS firmware on it. Most of my data closet switch( access layer) running CatOs. Does it affects the the access layer switch if i migrate all of my core switch into IOS considering I change my configration too.
All the access layer swithes running CATOS are connected directly with either one or two of core switche.
Please advise
thnx
subharose
Jon Marshall Thu, 09/11/2008 - 10:56
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Subharose
Without a detailed knowledge of your setup this can only be a generic answer but there should be no trouble having your core/distro switches running IOS and your access-layer switches running CatOS. At the last place i worked this was quite a common setup for us.
Jon
subharojdahal Thu, 09/11/2008 - 11:05
thanks jon
thanks jerry
jerry,
What do you mean line cards boot up correctly ? What causes the line cards boot up incorrectly ? If you are talking about the configuration of the ports on the line card that makes it booting incorrectly, then it makes sense to me. Otherwise, I would appreciate your further advise or explaination.
Jerry Ye Thu, 09/11/2008 - 11:12
  • Cisco Employee,
Sorry for the confusion, what I mean by "boot up correctly" is all the line card is supported with your new supervisor engine and IOS software. Just a quick example, the 6608 T1/E1 line card (for voice) is not supported in any IOS version, but it is supported with CatOS.
HTH,
jerry
subharojdahal Thu, 09/11/2008 - 11:44
Alright Jerry
That makes sense to me. We have been using only GBIC and RJ-45 line cards. So, it shouldn't be a problem. But wondering about the IDSM2 service module ? If I convert the config file correctly, then Do I still need to configure IDSM2 service module or it will automatically come up when I upload IOS version of config file.
Please suggest
subharose
Jerry Ye Thu, 09/11/2008 - 18:47
  • Cisco Employee,
Hi Subharose,
I am not familiar with IDSM2. However, according from the following document:
http://www.cisco.com/en/US/docs/security/ips/5.0/configuration/guide/cli/clilogin.html#wp1029987
IDSM2 is accessed via "session" command. Which make me to believe the IDSM2 is like the other service modules, that they have their own OS and config. And they are stored inside the service module. I don't believe there will be any issue if the config is converted correctly.
HTH,
jerry
paul.matthews Thu, 09/11/2008 - 22:44
  • Silver, 250 points or more
As has been said, the catos/IOS position on core switches should not make any difference to disctribution/access switches.
I do note, howber the little throwaway "considering I change my configration too" In what way has your configuratio changed? as long as the behaviour of the switch is the same - PVST/MST/Spanning tree roots/VLAN database/VTP Domain/VLANs trunked on ports/Trun protocols etc then there should be no impact. If you have taken the opportunity to tidy things and made a few changes, there may be an impact but without knowing details we cannot say what they would be.
Paul.
subharojdahal Fri, 09/12/2008 - 10:52
thanks guys,
Let me kick start the migration project and see what happens. I am hoping that things will go pretty smoothly
thnx
subahrose
