VPN between ASA and router
Sep 11th, 2008
I had a working vpn configuration between a local and a remote router; the remote router is not under my administration.
Now I moved the vpn termination from my side to an ASA5540 software version 8.0(3). The tunnel is up but there is no reachability. The "show crypto ipsec sa" on the ASA shows encapsulated packets but NO decapsulated packets! Routing and no_nat are properly configured.
Any idea?
Many thanks.
Overall Rating: 5 (1 ratings)
georges.merhej Thu, 09/11/2008 - 11:21
Hi Joe,
They didn't change anything from there side! It was fully working exactly before I've migrated to the ASA!
Have you used the packet tracer feature in the ASDM?
I would run a packet from source to destination using your adsm and see if it is fully going out as planned.
I suspect a stale xlate on the firewall, perhaps the other side that didnt change is hearing a different source that it wants?
Another option to consider is since the other side is using IOS (right?) they may be using GRE/IPSEC of some type and need to re-config to work with the ASA.
-Joe
georges.merhej Thu, 09/11/2008 - 11:54
I've attached the old router configuration.
Using the packet tracer:
inside-outside -> everything is fine
outside-inside -> ipsec-spoof detected! it's a normal behavior right?
francisco_1 Thu, 09/11/2008 - 12:12
  • Gold, 750 points or more
For traffic that enters the security appliance through a VPN tunnel and is then decrypted, the sysopt connection permit-vpn command in global configuration mode to allow the traffic to bypass interface access lists.
can you do some debug on the ASA.
debug crypto ipsec and debug crypto isakmp and send us the output
francisco
francisco_1 Thu, 09/11/2008 - 12:18
try "no crypto isakmp nat-traversal"
francisco
francisco_1 Thu, 09/11/2008 - 12:27
try from global"clear crypto ipsec sa" and "clear xlate". Also get them to do the same on the other side.
do a continous ping to the other side
going back over the notes your provided;
see the issue now?
DE-DC-INT-FW01# show crypto ipsec sa
Crypto map tag: IPSec-VPN, seq num: 40, local addr: 213.184.187.98
and now...
interface GigabitEthernet0/1
description $ES_WAN$$FW_OUTSIDE$
bandwidth 1000
ip address 213.184.187.98 255.255.255.240
ip access-group 101 in
ip verify unicast reverse-path
no ip redirects
no ip unreachables
no ip proxy-arp
ip virtual-reassembly
ip route-cache flow
ip tcp adjust-mss 1200
crypto map VPN
so, my question,
what is in front of the asa, and does it arp reach the ASA to get to 213.184.187.98?
where does the ASA has this addr config'd?
-Joe
georges.merhej Thu, 09/11/2008 - 12:33
the 213.184.187.98 was the ip address of the outside interface of the router, now the router is removed and the same ip is configured on the outside interface of the ASA.
francisco_1 Thu, 09/11/2008 - 12:36
I noticed you dont have crypto isakmp enable [Inside Interface]
georges.merhej Thu, 09/11/2008 - 12:37
the vpn is terminated on the outside interface, so there is no need for isakmp on the inside, right?
francisco_1 Thu, 09/11/2008 - 12:47
mmm yeah. i checked on my lab ASA 5520 on a working tunnel and i have it enable on the inside/outside as well.
georges.merhej Thu, 09/11/2008 - 12:54
I have tunnels configured and the same interface and working perfectly
francisco_1 Thu, 09/11/2008 - 12:57
you mean you have other tunnels active on the ASA?
georges.merhej Thu, 09/11/2008 - 13:01
yeah other tunnels are active! the 213 is the outside ip of the asa; the conncetion is like this now:
asa (public 213.184.187.98) -> sw (layer2)-> router (private IP with no security controls)->ISP
francisco_1 Thu, 09/11/2008 - 13:03
joe's got a point here. according to the logs
DPD (Dead Peer Discovery).
IPSec has a mechanism for a peer to send a notification to its peer when it is deleting a SA. This notification is sent via IKE. However, there can be situations in which this notification never gets sent. A usual reason for this is that the peer goes dead too abruptly e.g. system crash, unplugging the Ethernet cable, etc. Due to such events, one peer could keep sending data to the dead peer and it results in data loss. For this, a Dead Peer Discovery (DPD) mechanism is used. Make sure nothing is blocking the ipsec traffic between your ASA/Router
georges.merhej Thu, 09/11/2008 - 13:08
There's only a layer 2 switch between the router and the ASA and no security controls are configured on the router:(
my next educated guess;
turn off nat-t on the ASA the other side may not support it, not have it configured or UDP 4500 may filtered somewhere in the path
now clear ipsec sa on the sa, and continue testing... send interesting traffic to bring the tunnel back up
francisco_1 Thu, 09/11/2008 - 22:45
Georges/Joseph, Is this sorted?
Please let me know
Francisco
georges.merhej Fri, 09/12/2008 - 00:43
Guys,
It's resolved by editing the crypto/no_nat access-lists to match only host by host! It's really weird that it was not working with subnet to subnet access-list.
jimmyc_2 Wed, 05/29/2013 - 07:33
Thanks for posting the solution.  Any future info on this?   jimmyc
