Cisco AnyConnect: Persistent Connection during windows logoff
Sep 11th, 2008
I've got Cisco AnyConnect SSL Setup so the Start-Before-Logon feature works perfectly and we can start a VPN connection before logging on to the pc. This allows us to load the roaming profile from the server as expected.
Now I noticed that during logoff, the connection is shut down. Therefore, the roaming profile isn't updated.
Any ideas how I can fix this?
PS: running the latest version of Anyconnect and Pre-Logon add-on.
