singhsaju Thu, 09/11/2008 - 12:12
  • Silver, 250 points or more
Hi Carl,
By default firewall interface does not respond to ping,traceroute(icmp pkts) being security device . However, you can configure its interfaces to respond to icmp .
enable following commands:
icmp permit any outside
icmp permit any inside
Saju
Pls rate helpful posts
carl_townshend Thu, 09/11/2008 - 12:26
is that part of an access list or seperate commands? and why do you need to do it on the inside , does the inside not respond to ping by default, i can normally ping the inside by default
singhsaju Thu, 09/11/2008 - 12:31
no they are just commands . Just input those commands when you are in config mode.
check your config , maybe its already enabled for inside interface.
