Unity Backups
Sep 11th, 2008
Hi guys, we have a Unity on box server (its a secondary in a failover pair). We want to use an Symantec backup software to backup the system - however the customer has a policy not to back up messages. Is it possible to backup a Unity server (or an exchange server) so that it can be recovered without the exchange data i.e. can we back it up for recovery purposes without backing up and recovering the messages.Hope this makes sense...Jag.
Jaime Valencia Thu, 09/11/2008 - 12:56
i'm really not familiar with the Symantec backup tool but DIRT for example can only save Unity data and not the messages, that way you would only recover the unityDB and greetings, etc. but no messages. you would need to go thru the help of the product or give Symantec a call about this to know whether the product can do what you want.
or simply use DIRT and don't check the checkbox to save the mailboxes
java
if this helps, please rate
askq2forum Thu, 09/11/2008 - 13:23
Hi thanks for the reply. I know the functionality of DIRT - my question was specifically for restoring an exchange server (albeit it has Unity on it).
