How to hide pre-shared keys in the running-config
Answered Question
Sep 11th, 2008
Hi guys,
I've covered almost all passwords by issuing the command 'service password-encryption'
However, there is still one key that I am still able to see when I do "show run" and that is the pre-shared key that my router uses to establish an IPSec tunnel.
What is the command to hide this key?
Correct Answer by robertson.michael about 8 years 6 months ago
Hi Angel,
I'm glad that worked for you. Here are a few links that discuss the command:
Command Reference:
http://www.cisco.com/en/US/docs/ios/12_3t/secur/command/reference/sec_k1gt.html#wp1179793
Configuration Example:
javascript:newWin('http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a00801f2336.shtml')
-Mike
Hi Angel,
Depending on what software version you are running on the router, you can use the 'key config-key password-encrypt ' command (requires IOS 12.3(2)T or later). Here is a link to the documentation for this feature:
Hope that helps.
-Mike
Overall Rating: 5 (2 ratings)
Correct Answer
robertson.michael Thu, 09/11/2008 - 12:54
  • Silver, 250 points or more
Hi Angel,
Hope that helps.
-Mike
insccisco Thu, 09/11/2008 - 13:08
Mike, you're the best. thank you
this did the trick.
Can you send me a link where this new feature is explained in detail?
Correct Answer
robertson.michael Thu, 09/11/2008 - 14:16
Hi Angel,
Command Reference:
-Mike
jamesgef Fri, 10/03/2008 - 12:30
However, for precautionary reasons and a better understanding of how secure this is, where and how is the master key stored?
I entered the master key for aes encryption, rebooted the router and tried changing the master key. Router correctly knew what the old master key was, therefore, needs to store the password somewhere.
Thanks!
James
