CCM 4.1(3) DN Parameter on Service
Sep 11th, 2008
We have a service from a vendor that requires a "DevExt" parameter with the phone DN on the service for each phone.
Is there any way to edit this so that it will grab the DN from the phone rather then having to specify it? If I could add something like...
http://server/service.foo?DevExt=#DN#
That would be super great, or something I can put in the parameter as a default that would work for ever phone.
The reason I ask is because we are building 1000 phones in the system and I am bulking them in using BAT. It wont let me define a parameter in the bulk tool for a service so I have to go back and touch every single phones profile in call manager.
Sascha Monteiro Fri, 09/12/2008 - 01:11
  • Silver, 250 points or more
setonhnet Mon, 09/15/2008 - 09:29
If I make it so its using AXL SOAP to get the DN number is that going to bog down the server if there are 5-20 requests per min?
Sascha Monteiro Mon, 09/15/2008 - 15:51
well, not really but the SOAP interface is not meant to be used real-time..
So I never recommend to use it like this, unless there is no other way...
There are 2 options I recommend;
1/ use the DN as parameter (pretty easy to do)
2/ create your own cache of device/DN, and i.e. sync once a night via AXL SOAP
setonhnet Tue, 09/16/2008 - 08:22
Gotcha,
Now I'm trying to use jsp to get the extensions with the SDK, I'm no programmer so this isn't easy for me. I tried using the speeddials as a template and changing the stuff to Extensions, but its not working. The .java files mention something about...
* If the optional loadExtensions flag is included and true, then AXL will also be queried for
* detailed information about the Phone's line appearances and this information can be
* subsequently retrieved by a call to getExtensions(). Since this creates multiple AXL queries,
* this parameter should only be used when Extension information is needed.
Gosh why cant we have something simple that says, heres the devicename, I want the primary extension back. (Yea probably what it does but I'm just not smart enough to make it work! lol)
